Charging issues and wondering - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 3 Post By Motor7
  • 2 Post By Yarz1
  • 2 Post By realshelby
post #1 of 5 Old 09-03-2019, 05:58 AM Thread Starter
timc490310's Avatar
I have a 2005 vee and was wondering how many people have had the magnets slide. I have 20,000 mikes on and was wondering if I should take a look or does everyone with the 1000 has this problem at some point. Thanks
timc490310 is offline
post #2 of 5 Old 09-03-2019, 08:29 AM
Motor7's Avatar
I'd take a look....and go ahead and JB weld them now. Then you can sleep peacefully....
Big B, realshelby and Gert like this.
15 DL650XT
Motor7 is online now
post #3 of 5 Old 09-03-2019, 08:50 AM
While you probably can't say "everyone" has the problem, enough do that it is a common concern. If you run an onboard voltmeter and watch the numbers, you'll get a good indication if an issue is developing. When my stator fried and I had to take everything apart, even at 55xxx miles my magnets had not moved. Every one of them was firmly in place. BUT, I did the JBWeld modification at that point. Now I know for sure they are not going to ever move. It is not a big or difficult project. Just make sure you clean between the magnets very well so as to remove all of the oil residue before applying the JBWeld. There are many threads, pictures and videos related to this modification on the forum.
Big B and Gert like this.
Yarz1 is offline
post #4 of 5 Old 09-03-2019, 09:18 AM
I will say again, there is evidence that the magnets moving together may shorten the life of the stator!!!
I won't get into the engineering principles of that, as they are above my pay grade. But I have had it explained to me by an electrical engineer......
If I bought a new rotor, I would JB Weld the magnets in it before installing. I consider it preventive maintenance. It does not apply to 2014+ DL 1000 models.
If you don't have an onboard voltmeter on your DL 1000, get you one now!
realshelby is offline
post #5 of 5 Old 09-03-2019, 05:16 PM
My magnets did not move but I filled in the gaps when I replaced the stator at 61k
neebob is offline
