Rear wheel bearing? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 18 Old 08-26-2019, 08:31 PM Thread Starter
Rear wheel bearing?
Checking out the bike I just bought, 2012 V-strom 1000. 30k miles. When I spin the rear wheel on the center stand I get a gravely sound besides the chain clicking over the teeth. Here's the video. You can barely hear it over the chain and wind, but listen for the groan/gravely sound especially when I spin backwards.
There's, also a gap on the front of that rubber washer thing between the swing arm and hub (See photo). It spins freely if I try to move it so I don't know if its just a dust shield or a sign of bad things. Also, on the center stand the rear wheel has a tiny tiny bit of play if I grab it at the top and try and twist side to side to make the read bearing clunk.
2007 Kawasaki KLR650 (Sold)
2007 Yamaha FZ6 (Sold)
2006 Yamaha FZ1 (Sold)
2003 Honda 919 (Sold)
2012 Suzuki V-Strom 1000
Delasangre is offline
post #2 of 18 Old 08-26-2019, 09:09 PM
oldjeep's Avatar
Read this. Sounds like the same thing i just got done fixing.
https://www.stromtrooper.com/dl1000-...hub-issue.html
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
post #3 of 18 Old 08-26-2019, 09:24 PM Thread Starter
Awesome, I am going to take the wheel off and inspect. I don't have a service manual yet, can you tell me the axle nut torque and socket sizes?
post #4 of 18 Old 08-26-2019, 09:46 PM
oldjeep's Avatar
Socket was whatever fit. Book says 72.5 ft lbs dry. Forum says 58ft lbs with antiseize.
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
post #5 of 18 Old 08-26-2019, 10:13 PM Thread Starter
Thanks, I'll take a look tomorrow, trying to budget for winter tires for my car and now the bike needs work, lovely.
post #6 of 18 Old 08-26-2019, 10:26 PM
A tiny tiny bit of play by hand is way too much.
RLBranson is offline
post #7 of 18 Old 08-26-2019, 10:28 PM Thread Starter
Ya and thats with the chain on still. I am going to pull the wheel and check the bearing tomorrow.
post #8 of 18 Old 09-04-2019, 10:23 AM Thread Starter
Update:
Last night I changed my rear wheel bearings and cush drive at 30k miles. I've got about 700 miles on the bike since I bought it about 4 weeks ago.
What I found was the last guy put the infamous spacer in backwards which is why I had so much slop in the sproket hub and toasted wheel bearings. Also not sure if this is how they come stock but the bearings in the bike only had a grease seal on one side, so I could clearly see the ball bearings on one side. My new bearings (All Balls) had a grease seal on both sides.
Everything now feels like it's supposed to and the rear axle is about 1/4 inch further forward since it's not taking up the slop in the sprocket. Will be test riding tonight.
post #9 of 18 Old 09-04-2019, 10:29 AM
oldjeep's Avatar
Update:
My stock bearings were also only sealed on the outside. Did you wind up getting the machined spacer, or did yours seem to space the sprocket hub correctly? That seems to be what ate everything up on my bike, was that the sprocket hub could not seat as far into the cush as it should have been able to, which allowed it to wobble on the spacer.
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
post #10 of 18 Old 09-04-2019, 10:51 AM Thread Starter
I'm fairly sure I don't have that problem, apparently 2012s are most likely immune to that, and I checked that my chain is straight going up towards the drive sprocket, there's no play in my sprocket now, it's Rock solid against the wheel. But as with everything time will tell.
oldjeep likes this.
