Hello guys. The patient is DL 1000 2009.
Got a problem with the engine stall while hard braking. All TPS works were done (and the sensors are new), sparks, fuel and air are okay. Hot idle ab. 1300 rpm. Magneto is also new, so I guess there are two possible reasons: either a clutch switch or a tip-over sensor. I'll check the TOS as manual says. In addition, the clutch switch has an issue: it works fine at engine start, but I can't press the lever to hit it while riding (2 fingers on grip won't let it be pressed enough). Checked on stock and 2 aftermarket (levers and switches)- same problem there. So if this is the only possible solution - will the change to banjo with pressure switch help? And can it mess up the ECU while shifting (AFAIK this switch influences the injector and ignition timing)?
Any other ideas would be appreciated. Thanks in advance!
I had the same problem on my 2009 DL1000. She would start fine but once the motor was hot it would stall on hard braking. Note that the idle speed was also around 1300 (normal).
1- What I did was do a throttle body sync, where you adjust the vacuum on both throttles.Mine were off by a fair margin. There is plenty of info on this site or Vstrom Riders international. Once done you may have to adjust the idle again. Solved my problem.
2- This year I decided to adjust the throttle cables as I felt they were a bit loose. The same problem started again as the revs would briefly fall below 1000 rpm as soon as I took my hand off the throttle, however it turned out that I had tightened the return cable a bit too much, loosed it a bit and all is well.
I have 136000 km on mine and no sensors changed yet :smile2:
Hard miles, thanks for the reply.
Throttle bodies synced along with the TPS adjustments - that's the first I've done (not myself, our local Strom service, but I've been watching all the process).
This can be a problem as I've installed handlebar risers. But the revs never fall below below 1000 while driving, only at braking (ie I can leave the throttle intact and the revs will slowly go down to 1200 or so. But while braking they can drop to 700 for a second). So I think it's not an overtightened or loose cables, but will check.
93000 so far and second change. I can't imagine what's leading to their death, but they come out of range. And it's the Moscow Strom society's problem, not just mine...
.... I can't imagine what's leading to their death, but they come out of range. And it's the Moscow Strom society's problem, not just mine...
"In my case since the return cable was slightly too tight" when suddenly decelerating it's as if it kept the rpm's below 1000 just long enough for it to stall.
I'd suggest that you bridge the clutch switch to test if the issue still occurs. No problems, then it is the switch. If the stalling problem continues, look elsewhere.
Take the bridge off once you have done the test.
As well as the TPS another common problem is the side stand switch. Try zip tying the sidestand up.
Yeah the sidestand's spring were loose, got 'em tight. But that didn't solve the problem.
Bridging the switch is an idea, I didn't think that way as the dead and bridged switch often cause the problem like mine (stall while idling).
Hmm, I've noticed a burnt lamp in the brake light (5w is good, but the brake spiral won't light). Sounds a bit odd, but I've thought about electrical problems. Will take it out tomorrow and hope there will be a chance to try.
You should NEVER hit 4 bars temp. 3 Max. The fans will kick in at 3 and keep it there until it goes back to 2 bars, which is normal. Someone here may chime in and say, "I hit 4 bars sometimes for a few seconds," but they don't live in Moscow; they live in Dubai.
You may have a cooling system problem or something else causing the engine to run hot. Obvious suspects include the rad cap and thermostat and fan. It could also be the radiator is clogged or the water pump is not functioning well.
Yeah valves were done at the beginning of the season about 3k km ago. In my case 4 bars were seen with a bad TPS. After it was changed 3 bars max. But it may be a good idea to order the cap in advance.
Hmm. I have mixed feelings about the stuff.
1. One of rear lamps didn't light at braking - got it out, inserted back - everything fine. Will replace it later of course as the contacts seem to be flattened a bit. Don't know if this can be a problem .
2. Did a bridge for the clutch switch. So the bike started without pulling the clutch and I've let it warm up to 1 bar. Then headed home and:
a)it seems to be a bit antsy under 3000 rpm (with clutch switch in proper postition it goes smoother at 2500 revs)
b)while braking and hard braking the revs drop to 1200 and not lower (with the switch working they could drop to 700)
c)while idling at traffic light the revs float 1200-1400 with about 10 secs pauses at peak (i.e. 1200 - slowly rising to 1400 - 5-10 sec - dropping to 1200 - 10 secs - 1400 ....).
If you are sure that the engine responds differently with the clutch switch bridged then you should replace it. (SWITCH ASSY, CLUTCH 57560-02FA0). Are you confident that there is no wear in the lever, that the tab is correctly operating the switch, and that you are not over thinking it?
Fluctuating idle speed will not be because of that switch. That could be a whole list of possibilities, including, as Rolex says, a vacuum leak, or a fuel flow/quality problem. Perhaps you have more than one issue to resolve.
It's getting cold and snowy so I hope to run few more tests on the road with clutch switch enabled and then the bike will go to it's lair where we'll make make tests for vacuum leak, change the fuel filter and run the fuel test and so on. Thank you all for the advices, hope I'll be able to solve the problem which isn't a critical one but rather annoying.
Hello all. After the winter and all that COVID stuff I've finally tested my Strom with a banjo bolt with switch (Goodridge). It seems that the problem is gone and the cause was in the OEM switch not pushed by a clutch lever.
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
