Rattle sound - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Rolex
post #1 of 6 Old 08-20-2019, 07:21 PM Thread Starter
Rattle sound
I am sorry to sound like a broken record because I have read alot of rattle forums. This doesn't sound like the clutch basket thing. It happens when holding steady speed or decelerating, sounds like shaking a bucket of nuts and bolts. It almost sounds like it might be small exhaust backfires that im hearing through the front header, but I just worry it might be something like a loose timing chain? Not super familiar with the inner workings of the DL1000 yet.
Mine is a 2012 with 30k miles.
2007 Kawasaki KLR650 (Sold)
2007 Yamaha FZ6 (Sold)
2006 Yamaha FZ1 (Sold)
2003 Honda 919 (Sold)
2012 Suzuki V-Strom 1000
Delasangre is offline
post #2 of 6 Old 08-20-2019, 10:17 PM
Rolex's Avatar
Have a good look at your crash bars if you have them.
Every time I have been asked to find the source of a noise on a Strom it has been the crash bars.
Fit a ratchet strap to the bars and pull tight, then ride to see if anything has changed.
This can be done with many parts of the bike to help find the source.
Good Luck
RLBranson likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 6 Old 08-20-2019, 10:23 PM Thread Starter
Good Luck
Thanks, they seem tight, but I will try that.
post #4 of 6 Old 08-21-2019, 08:22 AM
Good Luck
I coincidentally had a rattle that came from light brackets mounted off the crash bars. I found the source of the noise last night
vinnie is offline
post #5 of 6 Old 08-21-2019, 01:21 PM
My '03 has a similar (based on your description) rattle from the front end. Sounds like it could almost but not quite be under the front header pipe. Mine turned out to be the 'bridge of the nose' between the headlights, right at the very bottom. Try just tapping at the bottom of the plastic headlight separator all the way at the bottom and see if your getting some clatter from that plastic vibrating.
2003 1000Vstrom
1973 BSA Thunderbolt
1971 Triumph Bonnie chopped
j_a_stump is offline
post #6 of 6 Old 08-27-2019, 08:40 PM
When I got my 'Strom I had an terrible rattling noise. Turns out the horn had come off its bracket and was laying on top of the front cylinder head. Simple fix for it.
2005 DL1000, 25k
2009 Harley Road King 49k - RIP
2016 Harley Road King 4k
nicmartim is offline
