New Rear Sprocket changed Speedo - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By DXDL
post #1 of 4 Old 08-15-2019, 05:46 PM Thread Starter
I just went from a stock 42 tooth rear sprocket to a 44 tooth. Of course I knew that would change a few things. I actually like the difference in performance as I now don't have to be doing 80mph to utilize O/D and in town slower speed cornering is much smoother. But until I actually figure out how fast I'm going it will be harder to pass the PO PO patrol sitting with his radar out! I was in a fast flow of traffic and looked down at almost 100mph on the speedo!!! This seemed a little more extreme than I thought it would be. Anyone else have any experience with this and anything else I should worry about that is not the same as before? Thanks much!
steevestrom is offline
post #2 of 4 Old 08-15-2019, 07:39 PM
DXDL's Avatar
I went with a 16/45 gear setup which I knew would throw off my speedo. As most will tell you, your speed is about 8% off from the factory. I installed the SpeedoDRD healer and i set it with my GPS. Very easy to set up.
Link: http://shop.12oclocklabs.com/index.p...&product_id=59
WildDoktor likes this.
2008 DL1000
42,800 miles
Saddleman seat, upgraded stator, Shinko 705's, Chain Alignment Spacer, SpeedoDRD Healer, ATV High handlebar, Zumo 395LM GPS,
LED Headlight bulbs Kit 50W 6500k Fanless, Tusk Folding Shift Lever Black/Silver, Wide Black Aluminium Foot Pegs, Foot peg lowering kit,
Givi engine guards, clutch lever push rod mod, accessory fuse panel under seat, up and back risers.
DXDL is offline
post #3 of 4 Old 08-15-2019, 07:42 PM
WildDoktor's Avatar
+1 on this!
Here's my writeup on my install.
WildDoktor is offline
post #4 of 4 Old 08-15-2019, 08:46 PM
Big Boy's Avatar
This 'fixed' the speedometer reading for my 45T rear sprocket. Mine was reading 10 mph high at an actual 65 mph.
W. C. Fields
Big Boy is offline
