Need help with tps - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 07-21-2019, 03:28 PM Thread Starter
timc490310's Avatar
Need help with tps
Does anybody know how to test a tps , would appreciate any and all help. I am thinking there is a way to check with an ohm meter but I need what the numbers should read and if I can read it on the bike. Also would the code come up in dealer mode if its bad. Thanks
timc490310 is offline
post #2 of 2 Old 07-22-2019, 04:40 AM
Gert's Avatar
The TPS is basically a variable resistor. Think of a worn radio volume control, you recall that scratching volume as you turn it. Cleaning may help but its best to replace it! There have been cases where a cleaning has helped, but not for long. See https://www.sportbikes.net/forums/fz...ml#post2105110, for more info on the TPS assembly.
Gert is offline
