We fixed that Sumbitch! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #11 of 13 Old 07-31-2019, 11:32 AM
Sounds like deformed burned exhaust valves are causing the leaks.
Cryoman is offline
post #12 of 13 Old 07-31-2019, 01:49 PM
Well done on the diagnosis and treatment. I can't believe the cams were installed that way! Good catch.
I'm sure you know this, but a leakdown test will help find valve leaks quickly, and a few sharp raps on the valve stems while air pressure is applied will usually clear the junk out from under the valves. Techron will likely get rid of the rest. Hopefully it's all gone now and your clearances hold. DD
Dubldee17 is offline
post #13 of 13 Old 08-14-2019, 12:31 PM
Shaw's Avatar
What a ride this thread is!
Looking forward to hearing if this next one is the last time you'll have to tear down and check.
-02 DL1000 -(aka SLO-Strom)
-81 Honda CT70 -The Mini
Shaw is offline
