Messed up during valve adjustment.... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #1 of 19 Old 07-18-2019, 09:53 PM Thread Starter
Burttj03's Avatar
So I have a 2006 DL1000 with now 87,000 on it, and after two years of ownership (and putting on nearly 10,000 miles myself) I was ready to do all needed maintenance, especially the valve check/adjustment! So I read and researched and read some more, and was so ready to take this on! I did everything I needed to get to the point where I could check the valve clearances and adjust them if necessary. I pulled the front valve head off, turned the crank to where the cam lobes were in proper position and crank was on the FT mark, checked the clearances and found a few were too tight. So, curious to see what size shims were currently under the tappet buckets, I pulled both cams and checked. Then, I went to go check the rear. So, I turned the crank 270 degrees to the RT mark and made sure the rear cam lobes were in proper position, and then went on to check the clearances of the rear valves and pulled those cams to check the shim sizes, etc., and then it hit me..... I forgot to put the freakin front cams back in before turning the crank to the rear position!!! At this point I’m now freaking out, unsure what to do, so I try to guess where the front cams would be at that given crank position, and I try to set them back in and secure them down. Also unsure if I put the rear cams back in correctly, I make another dumb move and try to put one of the rear cams in a different spot from where it was.... I then I tried to rotate the crank, and eventually hit a point where I hit total resistance—I’m assuming which means the valves were touching the piston in one or both of the cylinders—and so my valves aren’t even close to the position they should be in, and I’m sure my timing isn’t even close....
I’m super upset, and made a dumba** rookie mistake.... if I would’ve just thought things completely through while doing it, then it could’ve been avoided, but the fact of the matter is I messed up, and I have no idea how to go about fixing this issue and getting the valves and cams where they are supposed to be to have proper timing.
Can this be fixed?? Can anyone help me solve this?? I will be forever indebted to you!!
Burttj03 is offline
post #2 of 19 Old 07-18-2019, 11:10 PM
I believe it can be fixed. You need to just go take a break. Get a good night's sleep. Come back to it in a day or two, anxiety free.
The cam shafts are engraved so you know intake from exhaust. On the gear part of the cam it should indicate front or rear cylinder too. And the gaps are measured when each cylinder is at top dead center (TDC) of compression.
If it were me, I'd loosen the cam cap bolts and work the bolts, caps and cams loose and remove. If the engine stopped while you hand cranked it (and you didn't go ape on it trying to force it to turn more even though it wouldn't) the caps and cams will be under pressure most of the way as you loosen the bolts. But everything should come apart just like the first time you did it.
Then you need to find TDC for #1 cylinder. Get a friend to help. Insert a long sturdy thin wooden dial rod down #1 cylinder spark plug hole. Make sure the rod is plenty long. As you crank the engine have your friend ensure the rod is absolutely straight into the sparkplug hole, not at an angle. As the piston comes up, the rod will reveal that. Once it get to the top and pauses as you SLOWLY crank, you'll be at TDC. The question then is which TDC. You need TDC compression. Look in the peep hole and see if the proper letter for the front can be seen. If you don't see them, crank the engine around again and using the wood dial rod you can tell when it is coming back to TDC again. Do the correct letters show up in the peep hole this time?
When you are at TDC compression the correct letters will show through the peep hole and you can proceed with cam installation. Just remember to check them once you get them in and tightened down. It is too easy to have them one tooth off -- which means you need to take them apart.
There are some great videos out there on UTube and this forum showing all the gory details of getting the cams back in "just right".
blaustrom and STCorndog like this.
Yarz1 is offline
post #3 of 19 Old 07-18-2019, 11:53 PM
blaustrom's Avatar
Burt, relax, it will live!
Just don't try to rotate the engine further. As Yarz says the restriction will go away once you take the camshafts out again, then the valves are all closed, no contact possible with the piston.
Now you need a service manual (or a copy of the relevant pages) so you can follow the procedure correctly and see the marks on the cam gears you need to look for.
Online info is also available but the book is the best way to do it correctly and step by step. NOTE: the timing procedure for the rear cylinder is NOT the same as for the front cylinder: https://www.stromtrooper.com/dl1000-...ing-fubar.html
https://www.google.com/search?q=dl10...h=790&dpr=1.25
jdfog2 and bigjohnsd like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 19 Old 07-19-2019, 01:24 AM Thread Starter
Burttj03's Avatar
Thank you both for the help!! I just went back out with a clearer head, popped out all four cams and realized that when the cams are out then the valves can’t be depressed, or opened! (DUH!) hahaha, then I went on to find TDC of the compression stroke for the front cylinder, popped in the front two cams, and then rotated 360 degrees, popped in the rear cams (lined up appropriately), and cycled the crank through a few rotations with no issues!!! Timing marks are where they should be on all four cams at each specific marking!
All hope is restored! Thankfully, with my ignorance, and your knowledge/aid, I learned a valuable lesson about this bike!
I ordered a manual as well, lol. I’ve watched some many YouTube videos about doing this procedure, but I guess you just can’t truly learn something until you do it yourself!
Thanks again guys,
Tanner
Burttj03 is offline
post #5 of 19 Old 07-19-2019, 01:36 AM
christophermarkfoster's Avatar
I find myself in that situation from time to time. You just need to step back, clear your head, then go back to it. You learn the most from these situations in my opinion.
jdfog2 likes this.
Chris
1. 2004 DL1000
2. Next bike
3. Next bike
4. Next bike
christophermarkfoster is offline
post #6 of 19 Old 07-19-2019, 04:10 AM
Getting a good nights sleep over this is the trick indeed.
I was reading this and I don't get it. Or rather, I think this is wrong but I'm not sure.
The markings that you can see through the peep hole are on the flywheel/rotor, which is connected to the crankshaft. Not to the camshaft. This means that every time the piston is at TDC, you will see the markings. Regardless of whether this is TDC on the compression stroke or TDC on the exhaust stroke. So you can't use this method to find TDC on the compression stroke. Right?
Also, if you removed all your camshafts for whatever reason, and you can't use cam lobe position to find where the compression stroke is, how do you find TDC at the compression stroke? Or is this one of those things that doesn't matter, as the ECU will sort you out properly?
jdfog2 likes this.
BackPacker is offline
post #7 of 19 Old 07-19-2019, 09:57 AM Thread Starter
Burttj03's Avatar
Well I had the spark plugs out of each cylinder, and after taking the cams out I rotated the crank a few times, and then used a zip tie down that I put down in the front cylinder to feel the piston coming up until it was near the top. Then, I checked through the peep hole to line it up with the FT mark.
I think I know you’re concern: whether knowing if it was in the TDC of the compression stroke or exhaust stroke, but my thinking is because all of the cams were out, then none of the valves were moving and it wouldn’t make a difference. So, I just found TDC of the front piston, then replaced those cams, turned the crank 360, put in the rear cams, and then cycled through a few times and all seems well.
I’m thinking I should be okay with this thinking, but someone please correct me if I’m wrong!
I haven’t reassembled the bike yet to test it, but I plan to tonight.
Burttj03 is offline
post #8 of 19 Old 07-19-2019, 11:04 AM
The thing is, if the engine would be an old-fashioned carbureted engine with magnetos then it would not matter at all whether you assembled your camshafts at TDC of the compression stroke or on the exhaust stroke. It's the camshafts, after all, which determines what stroke you're dealing with. The carburetors work because the intake stroke sucks the air/fuel mixture into the cylinders, and the magnetos can be based on the "wasted spark" principle, giving a spark at the TDC after the compression stroke (which is useful) and giving a spark at TDC after the the exhaust stroke (which is wasted). So if you install your camshafts two strokes (one revolution of the crankshaft) out of alignment, things would still work. I think.
But this is a fuel injected bike, with an ECU. So it's the ECU which determines when fuel is delivered, and when the spark plugs should fire. Therefore the ECU needs to know at which stroke the engine is, but AFAIK the ECU only has a sensor on the crankshaft, not on the camshafts. So I'm trying to figure out how this feedback loop works, and by extension, what happens if you were to install the camshafts 2 strokes (one revolution of the crankshaft) out of alignment.
I'm pretty sure that you're not going to cause permanent damage. After all, in both cases the valves are closed when the piston is at TDC so there's no chance of the piston hitting the valves. But will the engine run?
Last edited by BackPacker; 07-20-2019 at 09:03 AM. Reason: Got my camshafts and crankshafts mixed up.
post #9 of 19 Old 07-19-2019, 12:01 PM Thread Starter
Burttj03's Avatar
The thing is, if the engine would be an old-fashioned carbureted engine with magnetos then it would not matter at all whether you assembled your crankshafts at TDC of the compression stroke or on the exhaust stroke. It's the crankshafts, after all, which determines what stroke you're dealing with. The carburetors work because the intake stroke sucks the air/fuel mixture into the cylinders, and the magnetos can be based on the "wasted spark" principle, giving a spark at the compression stroke (which is useful) and giving a spark at the exhaust stroke (which is wasted). So if you install your camshafts two strokes (one revolution of the crankshaft) out of alignment, things would still work. I think.
Ahh, I see what you mean.
Well, if I reassemble necessary parts in order to try and start it and it doesnt run correctly, then I could probably just pull the front and rear cams at the current TDC FT mark that the front cams are currently set at, then rotate the crankshaft one full revolution back to FT and reinstall the front cams with the timing marks aligned appropriately? Then, go on to rotate the crank 360 degrees to FT and reinstall the rear cylinder cams with the timing marks aligned appropriately?
Burttj03 is offline
post #10 of 19 Old 07-19-2019, 12:19 PM
blaustrom's Avatar
You wont get an answer to the ignition system question, if it's wasted spark or not. I don't know the answer off hand. Start a new thread and ask specific. There will be members that know.
Blau2 2014 DL1000A
