2007 Vee Injector Spray Pattern? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By notacop
post #1 of 7 Old 07-02-2019, 03:50 PM Thread Starter
Does anyone know what this pattern should look like?
Cleaning mine with a reduced hose/carb cleaner and a 9v battery for power and I get a strong V pattern on both injectors. A flared vee.
Is it supposed to be a circle?
Suzee Quorum is offline
post #2 of 7 Old 07-02-2019, 07:18 PM
https://www.witchhunter.com/spraypattern1.php
I found this when I googled spray pattern. Don't know what Suzuki intends but if you have a good solid spray and both are the same your injectors may be fine.
I've never messed with them but always thought it would be like a pattern the water garden misters would produce to insure an even burn.
Hopefully a really knowledgeable person will make us know.
Gert likes this.
post #3 of 7 Old 07-02-2019, 07:37 PM Thread Starter
Excellent link.
Interestingly the injector has a four hole pattern exactly like the 4th row picture. However, the spray pattern is not at all like the corresponding picture on the right.
The spray pattern resembles row 3 picture on the right.
So this resolves nothing yet.
*Sigh*
post #4 of 7 Old 07-02-2019, 10:51 PM
I cleaned the injectors on my 2003 a few years ago using the same method. There were 4 holes in each injector. Each injector sprayed a flared V pattern as you describe.
fearandcommonsense is offline
post #5 of 7 Old 07-02-2019, 11:03 PM Thread Starter
My spray pattern looks like the picture, strong and steady in a widening or flared V. Which seems odd, given the four hole pattern.
post #6 of 7 Old 07-02-2019, 11:22 PM
BC Rider's Avatar
Four valves in the head. One stream for each intake valve I would think.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #7 of 7 Old 07-02-2019, 11:23 PM
That is how mine looked and I remember having the same concern. I believe I asked on here if it was right but no one seemed to be certain. I'm still running them. Wish I could be of more help.
