2007 dl1000 misses
Looked at a 2007 v 1000, decent shape, no farkles to speak of. Engine idles great and you hit the throttle and it jumps up. Put the bike in gear and go to pull out and it sputters and hesitates then once you get the load off it it runs fine. He said it recently just started doing it but not sure if he is just telling me that. Like I said it idles great , hit the throttle in gear and it misses, get the rpms up to 3 and it smoothes out, shift to 2nd and same thing, it hesitates and misses and up over 3 on the tach and its fine. has aftermarket exhaust and no power commander. I was thinking maybe a coil is bad, but would it miss just under a load? I did not hear any air leaks or air being sucked in. Any ideas would be helpful. Thanks in advance.
