brake light flasher - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 06-24-2019, 12:47 PM Thread Starter
brake light flasher
2006 DL1000. So many brake light flashers to choose from. Which is the best one for my bike?
If you get to it...
and you can't do it...
then there you jolly-well are,
aren't you?
---Lord Buckley---
NewSuz is offline
post #2 of 11 Old 06-24-2019, 01:16 PM
I have this one. So far it has been great.
https://www.amazon.com/Vololights-Mo.../dp/B00MEQ25X8
quattroman is offline
post #3 of 11 Old 06-24-2019, 02:35 PM Thread Starter
flasher
Thanks, but I'm hoping to find just the "black box" that works with the stock lights, not a whole other additional light
If you get to it...
aren't you?
---Lord Buckley---
NewSuz is offline
post #4 of 11 Old 06-25-2019, 10:29 AM
I have a now-discontinued version (G1) of the 3rd Brake Flasher:
Brake Light Flasher - Flashing Brake Light at 3rd Brake Flasher
On my '15 DL650, the flasher on the stock light -- both with stock bulb and LED replacement bulb -- was underwhelming. So I went with an auxiliary brake light to which I connected the brake flasher.
thirdofthree is offline
post #5 of 11 Old 06-25-2019, 12:33 PM
H8-3Putts's Avatar
I used the "Back Off" flasher, but on my 2017. Set up to alternate between blinking 5 times and holding steady when the brake is engaged.
Got mine at the link below.
https://www.adventuretech.biz/brake-light-modules.html
H8-3Putts is offline
post #6 of 11 Old 06-25-2019, 12:34 PM
I'm using this. Have had zero issues with it!
BackOFF? XP Brake Light Module - Signal Dynamics
2012 V-Strom DL1000
2007 SV650S - Traded for DL1000
Jeff DeWolfe is offline
post #7 of 11 Old 06-25-2019, 01:20 PM
Onboard Mass Damper
DesertBike's Avatar
I've been thinking of adding one of the various Signal Dynamics modules - just dreading the wiring work.
I need to look at Eastern Beaver's stuff. They may have some wiring harness extension or similar that would make the job easier.
2007 Vee
DesertBike is online now
post #8 of 11 Old 06-25-2019, 01:23 PM
Absolutely! I grabbed their harness for exactly this and it worked GREAT! No cutting of the existing wiring harness which is awesome.
DesertBike likes this.
2012 V-Strom DL1000
post #9 of 11 Old 06-25-2019, 01:29 PM
The back-off product is really nice and you can find them at Richland Rick's web-site (www.adventuretech.biz).
______________________________________
2012 VSTROM 1000 Adventure: Adventuretech fork brace and mirror risers; SW Motech centerstand and skid plate; Givi engine guards. (Sold, but still like Stromtrooper).
Honda NightHawk 250
Honda CB500S
Suzuki TS400
Jawa CZ350
BSSTROM is offline
post #10 of 11 Old 06-25-2019, 03:30 PM
Onboard Mass Damper
DesertBike's Avatar
That ship sailed already - didn't know about EB or their adapter when I added some extra tail lighting a couple of years ago, so I spliced in extensions to the tail lighting harness the "hard" way.
Even so, the EB Version 2 Brake/Tail/Signal Adapter seems like the easiest way to add in a BackOff module.
2007 Vee
