lean angle on side stand? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 37 Old 06-21-2019, 01:14 AM Thread Starter
Ennsync's Avatar
Question lean angle on side stand?
Hello Troopers,
Recently I have a feeling that my 2008 DL 1000 leans closer to the ground on side stand. is it me comparing this subcontiously with my other bikes or it is really leaning far?also a memenr of face book v strom seeing the picture of the bike alerted me about it. I am posting the photoe , can some one help me with the solution.
Thank you
Ride safe/Ride long
Ennsync is offline
post #2 of 37 Old 06-21-2019, 01:31 AM
christophermarkfoster's Avatar
I think they lean too far myself.
Chris
1. 2004 DL1000
2. Next bike
3. Next bike
4. Next bike
christophermarkfoster is offline
post #3 of 37 Old 06-21-2019, 01:58 AM
WildDoktor's Avatar
Yeah; that seems to lean much farther than mine does. Didn't you raise your rear suspension a bit?
Anyway, either use your centerstand, or strap a hockey puck to the bottom of your kickstand, or carry a bit of 2x4 with you, or...any number of other solutions!
notacop and Gert like this.
WildDoktor is offline
post #4 of 37 Old 06-21-2019, 10:42 AM
Same on my 04 Wee. I tried tightening up the pivot opening, no help. I carry a bit of 2X4 on a lanyard in the tank bag to make parking it more upright, don't park on a slant!
post #5 of 37 Old 06-21-2019, 02:23 PM
Big Boy's Avatar
I just recently picked up a 2012 V1000. When I first leaned it over onto the sidestand, I thought I'd forgotten to put down the sidestand!!! Scared the C**P outta me!!!
Yeah, they lean way too far over.
W. C. Fields
Big Boy is offline
post #6 of 37 Old 06-21-2019, 04:51 PM
teevee's Avatar
get down on the ground and tighten up the sidestand bolt. mine was ridiculously loose. i think that bolt being left loose causes the mounting bracket to bend out leading to a, for the most part, permanent excessive lean, though ya might be able to throw a coupla washers in there to fill in the space.
richlandrick, Gert and Ennsync like this.
'08 DR650, '07 DL1000
teevee is offline
post #7 of 37 Old 06-21-2019, 10:33 PM
You could get a sidestand plate or attach a piece of steel yourself to the bottom of the sidestand. You could also do wood, though it will wear more quickly. Cut out a disk of plywood and screw down thru the holes in the flat plate on the end of the tubular shaft. Experiment first with diff thicknesses of wood. (My '13 DL650 has holes in the sidestand plate).
Gert likes this.
Ratchet is online now
post #8 of 37 Old 06-22-2019, 04:11 AM
Gert's Avatar
Have you read https://www.vstrom.info/Smf/index.ph...,21586.0.html? Perhaps ask someone help you hold up the bike while you measure by how much the side stand must be increased, to have an idea of the addition height required. Once you have the measurement that you need, you can order or make an extension foot piece. Maybe the hockey puck idea is a good idea, in that, it can be height trimmed if required. Plus the hockey puck route is an inexpensive option.
Gert is offline
post #9 of 37 Old 06-22-2019, 10:00 AM
Charlie1982's Avatar
I think there was someone on here (maybe oydnar?) who ended up replacing the entire mounting bracket on his DL1000, after discovering, upon inspection, that the metal was fatigued and allowing too much lean angle. Anyone else want to chime in on that?
I tried bending mine back a bit, but it didn't seem to last very long. So far I just park with the kickstand foot on a piece of plywood or something similar, since mine didn't look bad enough to worry about.
Ennsync likes this.
Charlie1982 is offline
post #10 of 37 Old 06-22-2019, 11:08 AM
Gert's Avatar
Gert is offline
