Instrument Panel doesn't work when running - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Currenv
  • 1 Post By Gert
post #1 of 7 Old 06-20-2019, 01:15 AM Thread Starter
When I first turn my key to the on position, both the speedometer and odometer max out and return to zero. Then when I turn my ignition stop switch to the on position the instrument panel works.
Once I start the engine, the instrument panel, speedometer and odometer stop working. Sometimes the speedometer and odometer will come on for a few seconds,but never the instrument panel.
Any suggestions?
Resistance to Tyranny is Obedience to God
2005 DL1000
Belleview, FL
Unreconstructed is offline
post #2 of 7 Old 06-20-2019, 01:25 AM
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
For a first answer, with strange electrical issues; first things I'd check would be battery, cables, and the battery ground cable - the other end from the battery.
But others here are more expert and it may be that this is a KnownThing. I'll be interested myself in what the experts think.
Good luck with it.
Vinnie
Sent from my SM-T800 using Tapatalk
richlandrick likes this.
Currenv is offline
post #3 of 7 Old 06-20-2019, 04:29 AM
Gert's Avatar
It sounds like either the power supply or earth fed to the gauges is failing. Often an electrical feed can pick up via an alternate power source, if the main feed is interrupted, like via a bulb, resistor, etc, but as soon as the gauges requires more power / amps than the alternate source can provide, it fails.
My suggestion would be to obtain a wiring diagram for your ride and attempt to trace which of the power and earth feeds have failed. It may even be as simple as a blown / corroded fuse terminal. Let us know your progress.
Gert is offline
post #4 of 7 Old 06-20-2019, 07:03 AM
Griff2's Avatar
Perhaps some appropriate lube to the ignition switch or check fuses. Otherwise break the connection on the instrument panel loom section and reconnect. It might just be a poor connection on one of the pins.
Griff2 is offline
post #5 of 7 Old 06-20-2019, 07:11 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
A 2005 in Florida, my money is on terminl corrosion or an intermitent fault in a wire. Both peices of advice above seem sound.
richlandrick is offline
post #6 of 7 Old 06-20-2019, 09:10 AM
V-Tom's Avatar
There is a large white plug on the left side under the gauges. Take a look at the plug for corrosion, signs or arcing and/or bent pins.
..Tom
2015 DL1000 New July 2015 185,000+ km, 115,000 miles.
SMIDSY detailed report.
V-Tom is online now
post #7 of 7 Old 06-22-2019, 08:40 PM
Sagebrush's Avatar
I had an issue with the instruments dying, needle sweeps while riding. Then the bike would quit and be completely dead for a while. Switch was not getting power, no power getting past the starter relay. So, new relay and I thought it was fixed. Then it started having issues again.
The second instrument power issue ended up being a loose connection in the ignition switch. Soldering had broken loose. Put a newer switch in off a 2012 and I haven't had anymore problems with it since.
Sent from my SM-G960U using Tapatalk
Sagebrush is offline
