I know this has been beat to death probably... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-29-2019, 12:09 PM Thread Starter
Beyond2wheels's Avatar
So I've searched the forums and because my bike is an 02. I can't seem to find a definitive answer, either a spoked rear solution for early V1k's? I saw a post from woody's but can't find anything on their website, and for the most part when I search "spoked rear wheel for vstrom 1000" I get info for 2012 on. I have a spoke front end set up, if there's not a solution then I guess I'll make one.
Beyond2wheels is offline
post #2 of 4 Old 05-29-2019, 12:52 PM
Motor7's Avatar
Call Woodys, they are proabally the top tier spoked wheelcompany in the US and have a great reputation.
15 DL650XT
Motor7 is offline
post #3 of 4 Old 05-29-2019, 01:39 PM
PerazziMx14's Avatar
I am not sure if the 2014+ DL1000 spoke wheel is a direct fit if not with some careful measuring and custom machining you'll be golden. I'm sure there are many other spoke wheels from other manufacturers that are viable options All depends on how deep you pockets are.
PerazziMx14 is online now
post #4 of 4 Old 05-30-2019, 07:07 PM Thread Starter
Called Woody's, they told me not enough demand and there's not that many older stroms on the road.....
So plan B is likely going to be modify my spare DR wheel to fit. Axle size is the same, bearings are the same. Just need to space out the sprocket and brake disc
