new chain problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 13 Old 05-27-2019, 12:26 PM Thread Starter
new chain problem
hi everybody.i put new sprockets and rk 525 x-ring chain on my 2006 vee and drove it maybe around 50 miles and when i checked it seems to be not even.i mean when i rotate the wheel it gets tighter and looser.is this normal?or is the chain defected?
cenksinan is offline
post #2 of 13 Old 05-27-2019, 12:30 PM
Fox
Fox's Avatar
I don't think a new chain is supposed to have significant tight / loose spots.
How tight is the master link? If it looks frozen, you may have to replace it.
Also if you look at hub assembly relative to the wheel while it's spinning, is there runout?
Motorpsychology likes this.
Fox is offline
post #3 of 13 Old 05-27-2019, 12:36 PM Thread Starter
i have been using clip style master links in the last 10-12 years and never had a problem.and i didnt notice any weirdness on the hub as well.i havent done the spacer mod yet but planning on it but i dont think it would make a difference in just couple miles.
post #4 of 13 Old 05-27-2019, 02:30 PM
Of the many chains that I have replaced over the years, I've never had one measure exactly the same throughout the chain's run. I typically get a variation of about 5mm or so from spot to spot (tightest to loosest).
'01 SV650N
derj is offline
post #5 of 13 Old 05-27-2019, 08:41 PM
Brockie's Avatar
No, it is not normal.
Is there an obstruction in the bottom of one of the sprocket teeth? Check both sprockets carefully for any inconsistency with the teeth.
If it goes tight when the link is around either sprocket suspect the link.
Brockie is offline
post #6 of 13 Old 05-28-2019, 10:35 AM Thread Starter
problem solved.i found this solution on an aprilia forum and it worked beautifully.i loosened the sprocket nuts and then i took the bike to center stand.i found the tightest part and hit the back of the sprocket with a rubber mallet.repeat the process until all the spots are even.its close to perfect now.
Gert and Brockie like this.
post #7 of 13 Old 05-28-2019, 11:10 AM
Motorpsychology's Avatar
I've never heard of that before, glad it solved the problem.Thanks for posting!
"I never said half of that stuff."-Confucius
Motorpsychology is offline
post #8 of 13 Old 05-28-2019, 12:07 PM
Big Boy's Avatar
If all else fails - Get a Bigger Hammer!!!!!!!!!!
Brockie likes this.
W. C. Fields
Big Boy is offline
post #9 of 13 Old 05-28-2019, 12:47 PM
dravnx's Avatar
Funny you should post that picture. It's a bit of a controversy up here. The hammer was stolen and a reward offered. Who the "ef" steals an 800# hammer? An attorney contacted the artist to tell him the head was found on his clients property. The handle has never been found. The attorney's client wanted the reward but the artist did not want to pay it as the offer was for information leading to it's recovery of the hammer, not the locating or return of the hammer and the whole hammer wasn't recovered.
Summing up, the artist got back the hammerhead and the client got the shaft.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #10 of 13 Old 05-28-2019, 11:49 PM
Brockie's Avatar
Great story. So the client, or his buddy, stole the hammer and then wanted a reward for returning it? That does not work for me. Information leading to the conviction of the thief might work.
I would imagine that the artist intended that some company might purchase the item to promote their business.
It would certainly be an attention getter. There are many "big" works down under, mostly as tourist attractions. We have the big banana, the big owl, the big pineapple, the big crocodile, the big prawn, and my favourite, the big poo. The list is endless. https://en.wikipedia.org/wiki/Australia%27s_big_things
Brockie is offline
Chain Slack Rebel Trepidator Maintenance, Tech and Products. 37 03-06-2015 06:24 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 04:11 PM
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 145 03-31-2014 06:18 PM
chain master link problem AncientMariner V-Strom Service and Maintenance Questions and Discussions 2 07-31-2010 04:32 PM
