2012 DL1000 Flat Acceleration - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 13 Old 05-25-2019, 06:29 PM Thread Starter
Coming home from a 1600 mile trip to Oregon, I went to pass a car and it was like the bike was starving for fuel. The symptoms start at 6k rpm in all gears and at 100% throttle. If I back off the throttle, the power comes back, just not as it normally would at full throttle. I can really hear the butterflies opening with a deep throaty note, but the bike just stays flat. I have Leo Vince pipes with the baffles in, a TFI module that has worked flawlessly since I installed it when the bike was new. The bike has 80k miles. I adjust the valves regularly and use a K&N air filter. I'm wondering if it's the TPS, coils, mass air flow sensor ??? Directions on how to test items would be helpful, I also thought that the ethanol in Oregon gas might have an affect, so I ran techron in the fuel the last 400 miles. No change. Thanks in advance for any advice. Keep it simple please, I'm not a whiz at electronic stuff.
bigdogbandit1 is offline
post #2 of 13 Old 05-25-2019, 11:20 PM Thread Starter
Has anyone seen this post ? I don't see it in the new posts.
post #3 of 13 Old 05-26-2019, 12:05 AM
Sounds potentially like a clogged fuel pump filter to me........
V-Tom, emjrrider and dust_buster like this.
post #4 of 13 Old 05-26-2019, 01:07 AM
trapperdog's Avatar
I would agree with Brian. I’m sure someone will post up a link to fuel flow tests.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #5 of 13 Old 05-26-2019, 02:19 AM
V-Tom's Avatar
It sure sounds like clogged fuel filter.
It's a pretty easy and inexpensive fix. Hopefully the links to how to do it will show up soon.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #6 of 13 Old 05-26-2019, 12:55 PM Thread Starter
Is there an actual inline fuel filter, or is part of the pump?
post #7 of 13 Old 05-26-2019, 01:07 PM Thread Starter
I see a large filter that is connected to the pump for $200 bucks. Is that the filter you are referring to ?
post #8 of 13 Old 05-26-2019, 01:31 PM
Sounds familiar to me, wish I knew this 4 years ago after a scammed fuel pump replacement. Forum education is very much appreciated. Thanks to all the more knowledgeable Stromers than myself.🏍💨
emjrrider is offline
post #9 of 13 Old 05-26-2019, 01:45 PM
nvr2old's Avatar
The factory filter is internal(Fuel pump).
Here is a link to do the filter bypass and install a external filter.
https://www.vstrom.info/Smf/index.php/topic,6105.0.html
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #10 of 13 Old 05-26-2019, 10:10 PM Thread Starter
Well...I pulled the tank and pulled the fuel pump. The nylon screen was hardly dirty at all and the inside of the tank looked new. I cleaned what little debris was on the screen with carb cleaner and re-installed the pump and tank. I took if for a test ride. No change. The bike pulls hard using up to 90% throttle. Give it that last bit and it sputters and flattens out. Let off that little bit and it jumps back to life. Does anyone think it might be the TPS sending a bad signal to the computer at wide open throttle?
Need a 2002 - 2012 DL1000 OEM Shock for New Shock Project SV Racing Parts Wanted 0 12-14-2018 10:33 PM
2012 dL1000 wheels interchange with other years? vstromtom DL1000 from 2002-2012 2 09-14-2016 10:39 PM
will slip-ons for 2002 - 2009 fit 2012 dl1000 ? MMMHOSS General V-Strom Discussion 1 03-23-2016 03:33 PM
I'm looking at a used 2012 DL1000 - any clutch problems? Vstrom N Me DL1000 from 2002-2012 5 06-03-2015 12:30 AM
