Exhaust dents :( - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 20 Old 05-22-2019, 11:00 AM Thread Starter
Farkle Purchasing System
DesertBike's Avatar
Exhaust dents :(
Seems like I did this a while back, before I got the Enduro Guardian skid plate:
I hate it. Any way to fix this short of new pipes?
It doesn't seem to affect performance but is firmly in the category of Not Good.
2007 Vee with too many farkles and 50k+ (s)miles
DesertBike is offline
post #2 of 20 Old 05-22-2019, 11:02 AM
NOBODY can see it or know it's there but you, and that might not be a dent anyways.
cyclopathic likes this.
post #3 of 20 Old 05-22-2019, 11:27 AM
Probably
Probably will not affect performance significantly. Try to forget about it.
DesertBike likes this.
Jimding is offline
post #4 of 20 Old 05-22-2019, 11:40 AM Thread Starter
DesertBike's Avatar
Those sure look like dents to me.
eta: Anyone with a Suzuki centerstand care to upload a photo from the same vantage point?
post #5 of 20 Old 05-22-2019, 11:54 AM
I have seen some actual dyno tests done where they tested rather major dents in header pipes. Before and after. The difference is almost not measurable. In fact a test showed an increase in one case.
About the only way to help that is to drill it, insert a screw, and use a pull hammer to pull it out. Then weld up the hole(s). In other words, not worth the effort!
realshelby is offline
post #6 of 20 Old 05-22-2019, 12:07 PM
I think it is clearance for the centerstand, hopefully someone can verify and I am pretty sure that both of my previous 1000's had the same indentions?
DesertBike and gorddl1000 like this.
post #7 of 20 Old 05-22-2019, 12:14 PM Thread Starter
DesertBike's Avatar
You may be on to something. I thought about that, but my SW Motech centerstand legs don't go there. However, that doesn't mean the Suzuki centerstand legs are the same. I just don't have a Suzi centertsand available to compare.
post #8 of 20 Old 05-23-2019, 10:43 AM Thread Starter
DesertBike's Avatar
This is definitely the approach taken when I get stupid and park in a downhill spot with no room to turn around.
Ever try to back out a DL1000? Even if you can flat-foot over the bike, it's sometimes easier to just get off and push. :P
post #9 of 20 Old 05-23-2019, 10:57 AM
vanislejay's Avatar
Based on my 03 Vee with suzuki center stand, the dent on the chain side if for the centerstand, on the other side there is no dent.
2003 DL1000
Too much other broken stuff to list
vanislejay is online now
post #10 of 20 Old 07-02-2019, 01:48 AM
Hilo Haole's Avatar
You could try filling the pipe with water and placing in a freezer. Might take a few tries to get the dent out. But is the trouble worth the outcome?
Paul
2005 DL 1000
2008 ST 1300
Hilo Haole is offline
Thoughts on Delkevic exhaust for my 2012 DL650 mattski1 DL650A - 2012-2016 71 01-03-2019 06:24 PM
Exhaust Install Problems bandroidx DL650A - 2012-2016 15 07-12-2014 05:43 PM
M4 Exhaust Install AdamThe3rd DL650 and DL650A - 2004 to 2011 4 01-30-2012 06:29 PM
