Adjusting screw on TPS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By larolco
  • 1 Post By bwringer
post #1 of 5 Old 05-20-2019, 06:50 PM Thread Starter
So today I decide I'm finally going to try to adjust the TPS on a 2007 DL 1000. I get the bike warmed up and put it in dealer mode. The bar is in the center position at idle and moves to the top position at 4000 RPM. So I remove some of the side fairing to get to the TPS. I see it in there with the slot for the screw adjustment. I use a T-20 bit with no luck. I look closer and it looks like an Allen head screw. I'm thinking someone changed the screw out in the past. I try an Allen wrench, and then another. No luck. So I get one I know is quite a bit smaller to check the hole in the screw. There basically isn't one! It's like the head has been filled in so you can't adjust it. Has anyone heard of this before?
shafferl is offline
post #2 of 5 Old 05-20-2019, 07:15 PM
bwringer's Avatar
It's a torx security screw; there's a little nubbin in the center to keep normal torx tools out.
You need a torx security bit with the hole in the center to turn it. (I seem to recall it's T20? Not sure.)
On my bike these went immediately into the trash and were replaced with M5 allen head screws.
And there are two of them on each TPS.
bwringer is offline
post #3 of 5 Old 05-20-2019, 07:58 PM Thread Starter
OK, never heard of that type of bit. I read it was a T-20 bit like you would find in any cheap tool set. Thanks. Why in the world would you need a security bolt back under there?
shafferl is offline
post #4 of 5 Old 05-20-2019, 08:29 PM
larolco's Avatar
To keep you and me from messing with it.
Replacing mine is on my to-do list. I suspect it is shot (lots of surging and getting worse over time). I have one on the bench ready to go. When I tested it, the bar would rise at high rpm sometimes, low sometimes - all over the map. Now the weather's smartening up and I've got my DRZ on the road (working on that today), I can spare the Vee for a bit.
shafferl likes this.
DRZ400SK17
larolco is offline
post #5 of 5 Old 05-24-2019, 09:49 AM
bwringer's Avatar
This is mentioned in most of the TPS replacement info, but it's worth repeating: when you pull out the old one, the seal is very likely to remain stuck in the throttle body. It's a little rubber air seal around the plastic shaft of the sensor.
Make double-sure you get this out before installing the new one. Two seals stuffed in there is decidedly ungood.
This has happened many times.
Gert likes this.
bwringer is offline
Help- how to remove stripped hex head screw chirosyd Maintenance, Tech and Products. 10 11-08-2014 11:02 PM
Clutch adjusting screw - How? Dave Dark V-Strom Service and Maintenance Questions and Discussions 3 09-27-2013 12:10 AM
Question on brake bleeder screw z33tec Maintenance, Tech and Products. 12 09-10-2012 11:04 AM
Can you help identify a screw? BigMan73 Maintenance, Tech and Products. 12 09-26-2011 05:05 PM
TBS Adjusting Screw is Inconsistant tomatocity DL1000 from 2002-2012 2 02-27-2009 04:55 PM
