Stupid battery question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
  • 2 Post By Yarz1
  • 2 Post By Hard miles
  • 1 Post By Billyn
  • 1 Post By Brockie
  • 2 Post By notacop
post #1 of 7 Old 05-14-2019, 08:45 PM Thread Starter
So, last fall my bike started struggling to start. Figured it was the battery. Crank over real slow , but eventually get enuff to start. I was gonna replace this spring, but when I got it out from the tender over winter, it started fine. Now it's doing the same thing, struggling to turn over but eventually starting. Now when it 50ampstarts, the clock is reset to 1:00 like it lost power. Thinking it's the battery but wanted to see if maybe I am missing something. I cleaned all connections. And if I put the 50amp quick starter on it, it fires up normal. I don't know how old it is. It's an interstate battery and I have had the bike 18 months, but the battery looks fairly old. Thanks guys and gals
Billyn is offline
post #2 of 7 Old 05-14-2019, 08:55 PM
if you live near an AutoZone store, pull the battery and take it in for them to load test. That'll tell you if you are about to be stranded in the middle of nowhere, in the dark, with falling temps and sideways rain, if you continue to use this particular battery and ignore the issue.
Brockie and DesertBike like this.
Yarz1 is offline
post #3 of 7 Old 05-14-2019, 08:57 PM
dravnx's Avatar
You put your key in the ignition and turn it. Your bike won't start. You need to find out why. You first have to determine whether you have a low battery, a dead battery or some other issue. Loose or dirty battery terminal connections need to be fixed right away. Clean, tight connections are essential.
If your lights come on, the bike won't turn over and you hear a buzzing sound (the starter relay) when you hit the starter button, you have a low battery voltage condition. This situation calls for charging the battery properly and then finding out whether it will remain alive or not with a load test.
Sometimes, your bike will crank over without starting and gradually slow down until it's dead and buzzing. This situation also calls for charging the battery properly and then finding out whether it will remain alive or not by load testing.
If your lights don't come on and nothing happens when you press the starter button, you have a dead battery, a blown main fuse or some other issue like a loose battery cable. The solution here is to install a known good and fully charged battery, verify the basics (good connections) and try again.
Motorcycle charging systems are basically low-tech and require proper care and feeding in order to work properly. The engine produces electricity, the regulator/rectifier manages electricity and the battery stores electricity. The first thing to know is that bike batteries can go bad and die from just a little bit of neglect. Lack of use is the kiss of death. Using a bike daily generally keeps the battery charged up, as long as it's not being ridden in constant short-trip mode. If your bike sits parked and unused for periods of time, the best thing you can do is to keep your battery juiced and maintained with an automatic charger. This is your best plan for having your bike start when you need it to. An automatic maintenance charger is cheap when compared to the cost, hassle and downtime of replacing a dead battery and will pay for itself in more ways than one. Don't cheap out- if you have a bike, you should have the appropriate charger for it. Not all chargers have an auto function, so check before use. You can easily kill a battery by overcharging it with a constant output charger.
Your battery is tapped into bigtime in order to start the bike. Cranking it over draws a lot of amps, so the battery has to be in good condition. The charging system gradually replenishes the juice used in start-up. On most motorcycles, there is a 3 winding stator coil pack and rotary permanent magnet (rotor) on the end of the crankshaft that spins when the engine runs that produces AC electricity. This juice then proceeds through the stator harness to the regulator/rectifier. Several things happen here. The AC electricity is changed into DC electricity by what's called a diode bridge in the rectifier. This component "rectifies" AC output into usable DC output so the bike can run. The voltage regulator then decides just how much juice to send back to the battery for recharging purposes and how much is syphoned off and lost as heat through the cooling fins on the regulator/rectifier body. Note: The charging system only works and puts out decent power when the bike is revved up to the 3,000 to 4,000 rpm range and above. Engine speed matters. At idle, the system is basically running at a loss because the stator output is minimal.
If you have a dead battery and replace it without checking the system vitals, expect it to go dead again. This replacement may get you running again temporarily, but you really need to find out why your other battery died in the first place so you don't end up stuck someplace with a dead bike. Testing a charging system is fairly straightforward. Your battery needs to be fully charged in order to test the charging system. You'll need a multi-meter in order to pin things down. The first thing to check is your DC charging voltage at the battery terminals. Set the meter to 20 volts DC and attach the positive and negative leads to the battery. This will give you your basic battery charge condition. A fully charged battery will have a free voltage reading of 12.6 to 12.8 volts. Start the bike, allow it to warm up and rev it up to 3,000 to 4,000rpms. Look at the DC voltage at the battery. You want to see about 13.5 to 14.5 DC volts when the revs are up. If it's above or below this range, you need to perform further tests. Shut the bike off and hook up the battery charger while you get ready.
If your DC voltage reading at the battery is above the 14.5 volt range, your voltage regulator might be defective. Too much electricity will roast that battery. Replace the regulator/rectifier and retest.
If your DC voltage is below the 13.5 volt range, your stator AC output needs to be tested. Generally, there are 3 wires coming off of the stator that go to the regulator/rectifier. Locate the stator harness (generally coming out of the left side engine cover) and disconnect the harness from the regulator/rectifier. You'll have 3 wires inside the gang connector, A, B and C. Set your multi-meter to 100 volts AC and check the readings between A to B, B to C, and C to A when the bike is revved up to 4,000rpms. Each of these 3 results should be the same, generally in the 50 to 80 volts AC range. If you find one or more winding with a low or zero reading, your stator is burned up and needs to be replaced. This replacement may fix things with no further work, but I have seen defective stators take out regulator/rectifiers because of the erratic voltage outputs. Testing the rectifier calls for an ohm test of the diode bridge to see if there are any bad diodes present. You'll need the service manual for your bike to identify the appropriate wires to test.
A bad stator or regulator/rectifier can also take out a battery. A well maintained battery will typically last about 5 years or so. If the battery is ever discharged or neglected, this lifespan can be shortened by quite a bit.
When all is said and done, a final DC voltage test should be done to verify the repairs were successful and you're good to go. If you're still feeling a little lost, it's best to get help from someone who knows the testing process. This will go a long way to taking the mystery out of charging systems and getting you back on the road.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #4 of 7 Old 05-14-2019, 08:58 PM
Hard miles's Avatar
see image (retry)
DesertBike and Hatchi like this.
Hard miles is offline
post #5 of 7 Old 05-14-2019, 09:06 PM Thread Starter
Wow man, thanks for taking the time. I will give that a shot to see what I find. It has a charging meter (sort of) on it. Green when bike is charging battery, red when it isn't. It's green always unless I let it sit at idle for a while with auxillary lights on... Or running low rpm on a hot day, sometimes it will flicker red. It was green the whole time I rode today. Not sure how accurate the device is though.
DesertBike likes this.
Billyn is offline
post #6 of 7 Old 05-14-2019, 09:22 PM
Brockie's Avatar
After reading your described symptoms I would first do as Yarz1 suggests and take the battery to an auto store to have it load tested. The battery definitely seems like the most likely culprit to me.
Brockie is offline
post #7 of 7 Old 05-14-2019, 10:18 PM
If the charger won't bring it up and a jumper makes it work, the battery is toast.
Eventually the battery will be so dead the jumper own't let the bike start with the battery still hooked up.
SEATS - Q&A -all you could ask and then some Skinnifatkid V-Strom Modifications and Performance 10 06-25-2019 08:38 PM
Major Electrical Fault DL1000 Sheds DL1000 from 2002-2012 58 05-04-2014 07:48 PM
Greetings and battery Question vacuum General V-Strom Discussion 20 02-09-2010 09:04 AM
Battery Tender question Scottie Boy DL1000 from 2002-2012 13 07-21-2009 10:23 PM
