2006 DL1000 charging issue again - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 31 Old 05-11-2019, 12:21 PM Thread Starter
1000 miles ago I JB Welded the stator magnets back in place and replaced the stator and v/r with Ricks parts. Everything worked great. Now when the bike is cold I get 14.5 v at 5k rpm at the battery but when the motor is hot I get 12.4 at the battery at 5k rpm. I tried another good v/r and I get the same readings. Before I take the stator apart I was hoping for some expert advice/opinion. Thanks, Jim
jimmyd is offline
post #2 of 31 Old 05-11-2019, 01:33 PM
Cannot say for sure about how your magnets are holding up. There have been a couple issues with the JB Weld fix when only filling the outer part of the channel and leaving the back part open.
But history shows Ricks and Electrosport stators are know for failing at a rate much higher than stock units.
Big B, Gert and DesertBike like this.
realshelby is online now
post #3 of 31 Old 05-12-2019, 06:29 AM
Gert's Avatar
Gert is offline
post #4 of 31 Old 05-12-2019, 06:34 PM Thread Starter
I pulled the stator out and don't see any black burn marks on it.
Is there a way to check the stator when it's off the bike?
Has anyone heard of the problem where it only fails when it gets hot?
jimmyd is offline
post #5 of 31 Old 05-12-2019, 08:13 PM Thread Starter
I found out how to take readings off the stator on the bike with engine not running. I'm getting unstable, varying numbers from .2-.7 ohms. Should they be a stable number?
jimmyd is offline
post #6 of 31 Old 05-12-2019, 08:44 PM
blaustrom's Avatar
Yes it has been reported that the problem may show only when the stator is hot. metals expand with heat at different rates, so this can happen.
Bench testing: The resistance readings between the 3 phases are not the issue (unless there is no continuity).
The problem is resistance of the 3 phases against ground (the metal parts of the stator). May not read bad when cold. If you find low resistance to ground = a short circuit to ground then not enough power getting to the rectifier/ regulator.
Are the magnets still in place as they should?
DesertBike likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #7 of 31 Old 05-13-2019, 08:35 AM
There is only one good bench test. One lead of an ohm meter to the steel case of the stator, the other lead to any one of the three stator wires. Check all three wires. ANY change in reading on the ohm meter is a failed test. Even 0.02 ohms.....
post #8 of 31 Old 05-13-2019, 05:58 PM Thread Starter
I did the test and it doesn't read for any of the 3 wires. 0 ohm's. Is that normal? Thank you
jimmyd is offline
post #9 of 31 Old 05-13-2019, 06:14 PM Thread Starter
I did the test but I'm not getting any reading on the the ohm meter for all 3 wires.
jimmyd is offline
post #10 of 31 Old 05-14-2019, 10:25 PM Thread Starter
I did the test to all 3 wires with 2 different ohm meters and don't get any readings
jimmyd is offline
Charging issue Cymro V-Strom Service and Maintenance Questions and Discussions 12 07-10-2018 09:29 AM
2006 DL1000 Control Layout kailuaboy84 DL1000 from 2002-2012 6 02-10-2016 09:29 PM
DL1000 charging system TooShaggy Maintenance, Tech and Products. 14 08-20-2013 03:40 PM
