Looking for TBS mod pics - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By Big B
  • 1 Post By viclava
  • 1 Post By bobbyvstrom
post #1 of 8 Old 05-11-2019, 10:55 AM Thread Starter
Send a message via Yahoo to viclava
I'm wanting to do the mod to do the throttle body syncing procedure, but have not been able to find where the hose sizes are and where to hook them up to the throttle bodies. I want to set the Vee up so it;s ready to do a TBS.
Can anyone direct me to that thread or mod page?
Thx
viclava is offline
post #2 of 8 Old 05-11-2019, 11:09 AM
There is a STICKY thread in this section.
post #3 of 8 Old 05-11-2019, 11:10 AM Thread Starter
All i could find is "How to" ref the throttle body sync, not the mod to connect the vacuum tubing and connectors for the TBS procedure. Am I missing something?
viclava is offline
post #4 of 8 Old 05-11-2019, 11:27 AM
It's in that procedure isn't it? If not it's as simple as pulling off the rubber caps, and installing the vac tubing extensions from the front/rear TB ports. You'll have to find the proper diameter male adapters for the ends of the lines, and then re-use the TB nipples if they aren't damaged. You can also use golf tees to plug the line extensions as well.
bobbyvstrom and DesertBike like this.
post #5 of 8 Old 05-11-2019, 11:35 AM Thread Starter
Found it. Evidentially, I needed two cups of coffee this morning before trying to read simple directions...
Big B likes this.
viclava is offline
post #6 of 8 Old 05-11-2019, 11:36 AM
If I remember correctly, the nipples with the rubber stoppers are on the lower part of the throttle body, very near the cylinder. Look for a black rubber "cap" that looks like a tiny black nose of a rocket. It's only about 1/4" long, if that. Good luck. Long nose pliers will be your friend.
WANDRR likes this.
bobbyvstrom is offline
post #7 of 8 Old 05-20-2019, 11:58 PM Thread Starter
Oddly enough, when I adjusted (or attempted to adjust) my TB's, I started off with fluids in each jar even, and when I started bike back up after hooking up hoses, the fluids never changed. I adjusted the screw back and forth with hardly any movement of fluid. It actually never changed. The bike seems to be running fine so far. I have done the TB's a few years back with my other Vstrom, and not sure why this time didn't change other than it wasn't in need.
Any thoughts?
viclava is offline
post #8 of 8 Old 05-21-2019, 10:15 AM
Onboard Mass Damper
DesertBike's Avatar
Any thoughts?
Your apparatus is leaky. It has to be.
I did my first (and so far only) TBS with a homemade apparatus like you describe. I found that it was VERY sensitive to even small adjustments. Eventually I had to settle for "only a tiny amount of transfer from one jar to the other" rather than perfect balance in vacuum.
Next time I do a TBS, I'm either buying a proper carb sync tool or making the yardstick-and-tubing-and-ATF type. The two jars setup is too sensitive and too easy to accidentally knock over (and then you have a mess!).
2007 Vee
DesertBike is offline
why can't new members post pics? NCK Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] 37 04-05-2019 01:31 PM
Happy-Trails Cascade or Teton Cliff-Cut Pics slapshot DL650 and DL650A - 2004 to 2011 13 01-08-2017 12:01 PM
What am I missing in the threads to see pics? bsherwood63 Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] 6 07-22-2014 12:39 PM
Posting Pics swimbikerun247 Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] 8 10-22-2013 03:16 AM
