02 1000 with pop noise on subtle deceleration - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-07-2019, 01:13 PM Thread Starter
Send a message via Yahoo to viclava
I was slowly rolling the bike into the garage yesterday in 1st gear, when I gave it a little gas and when i rolled off the throttle, it slightly popped. At the end of last riding season, it stalled on me a couple times while riding, but hadn't done it before or after. It idles good fine. Could this be the front and or rear intake pipe/boot?
I can see the front one with a light, and it doesn't seem to be gapped or loose, but cant see the rear without some disassembly. Or, could this just be a TBS needing to be done?
Any thoughts?
Thanks
viclava is offline
post #2 of 3 Old 05-07-2019, 05:11 PM
larolco's Avatar
Any thoughts?
Thanks
At that age, could also be an exhaust leak, though you'd probably notice it more decelerating from speed.
The stalling issue may be that your idle is set too low. Somewhere around 1200 rpm works best for me, some others a little higher. (Adjustment screw is on the left side of the bike, clearly visible).
If you haven't synced the throttle bodies, it can only help to do so. It's pretty amazing how big a difference balanced throttle bodies make. But if an intake boot has popped off, no TBS is going to help with that.
I'd check idle speed first and see if that helps. If not, then, I'd pop the tank, check on the air filter just because you're right there, and remove the airbox to have a good look at the intake boots. Then TBS.
DRZ400SK17
larolco is online now
post #3 of 3 Old 05-08-2019, 05:52 PM Thread Starter
yea, probably need TBS and go from there.
viclava is offline
650 v 1000 Skyy223 V-Curious 58 06-14-2019 10:11 AM
Hard to describe transmission noise lasemase72 DL1000 from 2002-2012 4 07-13-2014 12:05 AM
Dropped Wee and now have chattering noise 5500RPMs Vne Maintenance, Tech and Products. 12 08-21-2013 02:12 PM
Grating noise upon deceleration steve.smith V-Strom Service and Maintenance Questions and Discussions 3 09-10-2012 03:59 AM
Ding Noise...HELP! KeptMan DL1000 from 2002-2012 2 05-25-2008 02:16 PM
