Can spark plug boots be reattached? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By dmfdmf
  • 1 Post By Brockie
post #1 of 3 Old 05-05-2019, 08:00 PM Thread Starter
Gingie's Avatar
Question Can spark plug boots be reattached?
Short version - the boot part of the wire to the front plug came off, can I "plug" it back in? It looks broken off.
Long Version:
Bike is 2008 DL1000.
I got the front cylinder plug out (#5). I could not get the new plug in (#6). Looking at the tops, I thought that the hourglass shaped top on the new plug, must also have been on the old one, and somehow twisted off inside the boot (#1).
So, I ended up using a screw extractor, and out came parts 2, 3, 4.
In the process of moving the boot around behind the rad, it too became disconnected...or is it broken off...it looks like the wire it came off has no obvious connector.
Is this fixable? If so, anyone know the sequence of the white cylinder and the spring back into the boot..they just spilled out on to the driveway :-(
Or do I need a new boot & wire assembly?
I assume the hourglass shaped too on the new plug can unscrew.
Gingie is offline
post #2 of 3 Old 05-05-2019, 09:01 PM
dmfdmf's Avatar
Unfortunately it was the reverse. The hourglass shape needed to be removed from the new plug.
So, I ended up using a screw extractor, and out came parts 2, 3, 4. In the process of moving the boot around behind the rad, it too became
I think the wire can just be pushed back in. It engages with a barbed spear that contacts the center conductor of the wire. I would dab the wire insulator with some gasket sealant or similar to make sure it does not come loose down the road.
Is this fixable? If so, anyone know the sequence of the white cylinder and the spring back into the boot..they just spilled out on to the driveway :-( Or do I need a new boot & wire assembly? I assume the hourglass shaped too on the new plug can unscrew.
I have no idea what order those parts from the boot are installed. However, you could carefully disassemble the spark plug boot for the easily accessible rear spark plug boot. Just be careful, take your time and note what parts come out in what order and use that info to reassemble the front boot.
Gingie likes this.
Next Up: ?
dmfdmf is online now
post #3 of 3 Old 05-05-2019, 09:42 PM
Brockie's Avatar
This is fixable.
Some spark plugs need the "hourglass shaped top" and others do not. Your bike does not. Screw it off the plug.
Below is an image of the internals of a similar plug cap. Your part #2 is a resistor to prevent electrical interference. To confirm the order of installation check if either the spring, or the resistor fit most neatly against the upper surface of the brass retainer that holds it all in. Electrically, it does not matter which part goes in first but the internal dimensions of the cap probably dictate the correct assembly.
Deep in the top end of the cap will be a wooden screw type thread onto which the cap is screwed. Hold the wire and screw the cap on. Do not over-tighten. A sure coupling is all that is required. As the wire was wrenched off the end of it may no longer be secure and it may be necessary to chop off the end 3/8" of the wire to get a good connection. I believe that modern HT leads (the wire) no longer have copper wire in them and these days have a fiberglass core infused with carbon to relay the spark plug charge.
I've never looked.
Take your time. It will go back together.
Gingie likes this.
Brockie is offline
Can't Get to That Front Spark Plug! Any Tips? Ron Strommer Maintenance, Tech and Products. 13 03-01-2019 06:47 PM
Spark Plug Change at 7500 miles jmackd1 DL1000A - 2014-2016 24 04-01-2015 09:19 AM
Black Friday Pulstar Spark Plug Deal PulstarSparkPlugs Pulstar Spark Plugs 2 12-03-2014 12:58 PM
4WD Mechanix Magazine Pulstar Spark Plug Review PulstarSparkPlugs Pulstar Spark Plugs 16 11-07-2014 04:38 PM
New Sidi Boots Gray Devil General V-Strom Discussion 2 05-16-2011 11:58 AM
