02 1000 W/ coolant weep hole question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-02-2019, 06:15 PM Thread Starter
Send a message via Yahoo to viclava
I recently had the Werks clutch mod done and after putting everything back together, I have noticed that modest amount of coolant residue/evidence of coolant being expelled from the weep hole forward the water pump. My coolant level is between the low and high mark, and am not sure if this is evidence of a new water pump beinig needed or what. I had not noticed this amount of residue prior to my clutch job.
Any thoughts?
Thanks
viclava is offline
post #2 of 12 Old 05-02-2019, 07:14 PM
Did you replace the case seal with a new one and thoroughly clean the area? Was the issue evident before this job was done? Have you dropped your oil and checked for coolant in there?
Kaine Beedenbender is offline
post #3 of 12 Old 05-02-2019, 07:23 PM Thread Starter
Replaced case seal after thoroughly cleaning the case. there was slight evidence of some weeping, but wahat I would have considered to be normal. I have not dumped the oil since the clutch job, but I had put new oil in after the clutch job and have not put more than 100 miles on the bike since.
viclava is offline
post #4 of 12 Old 05-02-2019, 07:40 PM
Might think about replacing #4 / #5 here:
https://www.partzilla.com/catalog/su...000/water-pump
post #5 of 12 Old 05-02-2019, 07:45 PM Thread Starter
Hmm, I was thinking mechanical seal, but maybe your re correct.
viclava is offline
post #6 of 12 Old 05-02-2019, 07:45 PM
If you have not ridden the bike much, I would ride it some and get it up to temp and keep it there a while. These seals are know for allowing a bit of coolant to bypass them. More prominent in colder weather and after the bike has sat a good while. Often it clears up. The tube is there to allow this coolant to escape and not go into the crankcase/oil sump.
If you do rebuild the water pump you MUST replace the mechanical seal as that is the coolant seal. You will want to replace the other seals, o-rings, etc.
realshelby is offline
post #7 of 12 Old 05-02-2019, 07:50 PM Thread Starter
is there a waterpump seal kit, or do I have to buy them separately?
thx
viclava is offline
post #8 of 12 Old 05-02-2019, 07:52 PM Thread Starter
Realshelby,
BTW, my bike rides so much better now after your clutch. Thanks you again!
viclava is offline
post #9 of 12 Old 05-02-2019, 09:42 PM
thx
I think that link above will get you the 3 parts you need pretty reasonably, and it will be OEM quality.
post #10 of 12 Old 05-03-2019, 09:45 AM
thx
Parts 3,4, and 5 will get the job done. On really high mileage bikes I would probably replace the impeller while in there.
SEATS - Q&A -all you could ask and then some Skinnifatkid V-Strom Modifications and Performance 10 06-25-2019 08:38 PM
Coolant leak out of the water pump My Strom DL1000 from 2002-2012 48 06-19-2016 05:29 PM
Crash Bars/Skid Plates- Q&A - all you could ask and then some Skinnifatkid General V-Strom Discussion 11 05-29-2010 01:46 PM
LUGGAGE - Q&A - all you could ask and then some Part TWO Skinnifatkid V-Strom Modifications and Performance 1 05-29-2010 02:33 AM
Windshields- Q&A-all you could ask and then some Skinnifatkid General V-Strom Discussion 8 02-15-2010 08:51 PM
