Looking to bring bars up and back a bit - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 16 Old 04-29-2019, 12:23 AM Thread Starter
Hotrodsteve's Avatar
Last week I purchased a new to me 2006 dl1000. My first Strom. Looking to bring the bars slightly up and back for more upright position. Can anyone guide me on what I need? Want to ride to the NC rally in a few weeks but would like to have these on the bike before making that ride. Thanks in advance.
DesertBike likes this.
Hotrodsteve is offline
post #2 of 16 Old 04-29-2019, 12:53 AM
blaustrom's Avatar
How much up and back you want?
If more than about 1.5" to 2" then the hydraulic lines will be too short, unless you drop the forks by 10mm.
https://www.google.com/search?q=hand...h=863&dpr=1.25
Many choices. Rox risers are very adjustable and sturdy.
Gert and DesertBike like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #3 of 16 Old 04-29-2019, 12:54 AM
I got some bar risers and rearward-movers off ebay, cost buggerall. Took couple of weeks to arrive tho. They fitted fine - the lines etc were just long enough with a tiny stretch at each steering lock. Did the trick - less stretch and more rise!
DesertBike and Hotrodsteve like this.
GerardDeR is offline
post #4 of 16 Old 04-29-2019, 08:04 AM
Webfors's Avatar
I put these one without too much trouble, no need to replace cables:
https://www.revzilla.com/motorcycle/...ndlebar-risers
Gave me enough to be comfortable.
eff and Hotrodsteve like this.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #5 of 16 Old 04-29-2019, 11:09 AM
blaustrom's Avatar
Originally Posted by Webfors View Post
I put these one without too much trouble, no need to replace cables ...
You mean REPLACE or REROUTE? He has a VEE with a hydraulic clutch, not cable operated.
Blau2 2014 DL1000A
post #6 of 16 Old 04-29-2019, 11:15 AM
Webfors's Avatar
Neither, everything fit perfectly. Not sure about the Vee though.
'18 DL1000XT
post #7 of 16 Old 04-29-2019, 08:26 PM Thread Starter
I like the way those look. Is there any trouble with cables being to tight?
post #8 of 16 Old 04-29-2019, 08:52 PM
Webfors's Avatar
Not on my 2015 DL650. You'll need input from DL1000 owners to confirm.
'18 DL1000XT
post #9 of 16 Old 04-29-2019, 09:26 PM Thread Starter
Thanks for the info! I don’t want to have to change cables, I’m thinking an inch up and a inch or two back would be perfect.
post #10 of 16 Old 04-30-2019, 12:00 AM
blaustrom's Avatar
With your bike I think you can do 2" raiser without trouble if you drop the forks about 10-12mm in the tripple trees. A modification made by many quickening steering a little and a little less lift in the front at speed.
Another trick that some use, if the hoses and/ or wires are too tight, is to route them behind rather than in front of the upper tripple tree. If you do this make extra sure that there is no interference lock to lock. Also test that there is no throttle effect lock to lock with the engine running to be sure!
The more back you place the handlebar the more this mod will help:
Blau2 2014 DL1000A
Christmas Crash bars back from powder coating BluesUke Maintenance, Tech and Products. 5 01-18-2019 03:34 PM
Around Dubbo in NSW - getting a monkey fof the back gcoliver1967 Ride Reports (Route Sheets) 0 08-05-2018 06:26 AM
Changing stock bars BMiracleTX DL650A - 2012-2016 3 08-30-2013 05:48 PM
So...how far have you gone to bring one back from the dead? el-cid General V-Strom Discussion 15 07-17-2013 05:52 PM
