More 1000 Rough Running issues! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 12 Old 04-22-2019, 03:38 PM Thread Starter
After reading volumes of complaints,issues and resolutions I cannot decipher my own 2007 DL1000 problems.
It was running fine over the winter then I allowed it to sit for several weeks in February without starting.
The weather went below 32F overnight and it was in a carport.
When I did start it ran quite rough at idle and all RPMs under acceleration.
So I:
A) Changed the spark plugs
B) Slightly adjusted the TPS
C) Synched and double synched the Throttle Bodies.
D) Checked the intake boots twice for poor seating. Fine.
E) Changed the Air Filter (With the gasket reseated properly).
F) Checked all vacuum lines for degradation or disconnects.
G) Ran with the fuel cap open.
H) Added Seafoam to the gas tank and burned a few gallons.
I) Pulled the Pump/filter out of the tank, inspected (fine) but did a filter bypass anyway for future preventative care.
And it still runs much rougher than normal with a heavy drop of power.
Any ideas??
Suzee Quorum is offline
post #2 of 12 Old 04-22-2019, 03:53 PM
PerazziMx14's Avatar
Have you verified its running on both cylinders?
PerazziMx14 is online now
post #3 of 12 Old 04-22-2019, 03:56 PM Thread Starter
It did not seem THAT underpowered lol. How can I check/verify?
post #4 of 12 Old 04-22-2019, 04:00 PM Thread Starter
I will try this: "For future reference, you can spray or drip water on each of the header pipes. The one which doesn't steam as aggressively is your dead cylinder"
post #5 of 12 Old 04-22-2019, 04:49 PM
While the water test will work I'm more on an instant results guy. Start a cold bike on the side or center stand then quickly touch each down pipe. With a few seconds of startup if it warm its firing if its cold its not.
post #6 of 12 Old 04-22-2019, 04:50 PM Thread Starter
Warm after seconds. Quite warm on the down pipe (x 2).
post #7 of 12 Old 04-23-2019, 01:47 PM
Bad gas. No mention of gas replacement or if you inspected for water in your fuel. I had purchased some rotten fuel at an old gas station, bike wouldn't run below 4k and ran very poorly above. I had about a half tank and added fresh gas, improved and after running that out it started running correctly. You can add a splash of rubbing alcohol (90%) and this well help adsorb some of the water.
Dave C.
Hutto, Texas
On the Blackland Prairies, between the Coastal Woods and the Edwards Plateau.
DaveInHutto is offline
post #8 of 12 Old 04-23-2019, 02:22 PM
blaustrom's Avatar
Just to be sure check that the battery terminals and the grounds are clean and tight. You never know. Metal contracts when cold so there could be an effect.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 12 Old 04-23-2019, 02:37 PM Thread Starter
I did initially suspect either poor fuel or a rubber fitting shrinking in Winters late chill and dislodging something.
So there were several gallons sitting in the tank and I added Seafoam to that. Ran it up to 60 MPH on a back road nearby several times..and no effect. So then I siphoned most of the fuel out of the tank and added several gallons of Premium Unleaded. No change after returning to that same back road for about 5 miles at 60 MPH.
I am suspecting or hoping at this point that it may be an injector (s) and planning on adding seafoam to the several gallons of premium in the tank. The fuel filter mesh looked almost new under inspection.
post #10 of 12 Old 04-25-2019, 10:21 AM
bwringer's Avatar
A couple of other things I've seen to consider:
- Check for corrosion or water inside the various connectors. There's one connector that feeds both injectors that seems vulnerable for some reason; this is where a Power Commander plugs in, so if you have one check both connections carefully and make sure the PC ground wire is hooked up correctly to the battery and not the frame. There are several other connections that can affect running, like the coils. Take the tupperware and tank off and go through them all.
- You might consider having the injectors cleaned. It's quite possible for an injector to get sticky after sitting for a while. Some injector cleaning services refuse to service motorcycle injectors for reasons I cannot fathom (Vee injectors are bog-standard Bosch; absolutely nothing moto-specific about them), but some will. I'll need to do some digging to find the name of the service that did mine.
Big B and dudu like this.
bwringer is offline
2009 1000 running rough at 3200-3900 NewEngland1000 DL1000 from 2002-2012 12 06-19-2017 08:37 AM
Suzuki V-Strom 1000 Endurance Test York DL1000A - 2014-2016 4 06-09-2017 07:29 AM
2003 DL 1000 PC 3 running issue Adventure711 V-Strom Service and Maintenance Questions and Discussions 7 08-27-2014 04:50 PM
Help! Running rough from bad gas crosscountry V-Strom Service and Maintenance Questions and Discussions 19 11-25-2011 03:49 PM
Running rough and on 1 cylinder? klrman1 DL1000 from 2002-2012 28 05-09-2008 03:34 PM
