warning ligth and F1 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Demache
post #1 of 6 Old 04-22-2019, 02:27 PM Thread Starter
problem as descrived, when engine temp Reach 2 stripes F1 showes blinking and the red lamp comes on. Testing With mode selction switch shows C1, the book say there is nothing wrong. The engine goes as good it can be, so anyone has an idea?
peengda is offline
post #2 of 6 Old 04-23-2019, 03:29 AM
Gert's Avatar
Can you confirm radiator / water level, as well as oil level. I think that from two bars on, the thermostat will be starting to open, to allow water flow to cool the motor. A low oil level could also bring the oil light on, but that should be as soon as low oil level detected.
See this discussion https://www.stromtrooper.com/dl1000-...ght-stays.html
Gert is offline
post #3 of 6 Old 04-25-2019, 10:14 AM Thread Starter
Hi, water and oil is ok. the red ligth comes on after a few hundred meters, have chanced the oil presure switch but same thing hapend with warning ligth. engine seems fine and nothing make me feel unhappy when riding. Testing show C00 and the book sayes nothing is wrong.
peengda is offline
post #4 of 6 Old 04-25-2019, 11:02 AM
Demache's Avatar
Turning off the ignition will clear the code. Since it seems like you can reproduce it, put it in dealer mode then go for a ride. You should see the FI code pop up.
Gert likes this.
2007 V-Strom DL1000 (current!)
Previous:
1999 Honda Shadow VT1100C (2016-2017)
2003 Yamaha V-Star 650 (2012-2016)
Demache is offline
post #5 of 6 Old 04-26-2019, 02:34 AM
Gert's Avatar
... Testing With mode selction switch shows C1, the book say there is nothing wrong.....
I don't seam to find the dealer mode code C1 that you wrote about. A list of the dealer codes are in post #2 of https://www.stromtrooper.com/dl1000a...-question.html, for a quick reference.
Gert is offline
post #6 of 6 Old 04-27-2019, 08:03 AM Thread Starter
new cdi box is orderd (used). After testing with a friends cdi box wich works ok, i had to check my acount for money. So a used box is under way.
Thank you for all help.
peengda is offline
