Is there any improvement on wind going from 650 to 1000 - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #11 of 14 Old 04-22-2019, 08:56 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
This is a long forgotten fix that I used myself for nine years with a Givi D260ST screen. Remove the windscreen and windscreen carrier. What I'm calling the carrier is the plastic structure between the windscreen and the fairing. Get a 10 mm longer 6 mm bolts from Ace hardware and a 1" stack of 1/4" or 6 mm washers. Remount the carrier with a 1/2" stack of washers beneath the lower two windscreen carrier bolt hole.
this kicks out the lower art of the windscreen so that more air goes under it and moves the top of the wind screen slightly closer to your head. The reduces differential pressure from the front to the back of the screen that results the air remaining smoother longer and less buffeting to the helmet.
Step two order our mirror extenders. They will noticeably reduce air coming off the mirrors. Guaranteed.
https://www.adventuretech.biz/suzuki...extenders.html
richlandrick is offline
post #12 of 14 Old 04-22-2019, 09:19 AM
DonOhio45813's Avatar
Here's my old V1k, note the added wings on the screen, AND, the lexan shields from the fairing down to the crashbars. Those stop the wind that hits your legs and come up your torso. My current 650 has the same things PLUS a homemade MRA type spoiler on the screen. My 650 is as good as I've ever managed to get on a Vstrom
[IMG][/IMG]
DonOhio45813 is offline
post #13 of 14 Old 04-26-2019, 05:55 PM
Having a 2006 , I would have to say that my 18 1000 has wind turbulence much worse than that more fully "cockpitted" gen 1 wee.
The wind tugs my helmet upward, fills my sleeves and generally the ride is less enjoyable at highway speeds, so no I would not expect any improvement.Its hard to say where it comes from,they eliminated the lower shroud by the lower triple tree and put that scrawny narrow module dash above it and the results are what you would expect.
2006 DL 650
2018 DL1000A
jmvs is offline
post #14 of 14 Old 04-26-2019, 06:06 PM Thread Starter
timc490310's Avatar
I got the Aprilia mirrors of Ebay and have just got a short ride in. They make a difference but it was a short ride. I hit 75 on a back road and I am impressed. 40.00 for the 2 mirrors may have done the trick. Weather is crappy here so it will be a few days to get a decent ride in. Thanks for any input, keep it coming.
timc490310 is offline
2018 V-Strom 1000 Pre Purchase Questions Numbercruncher DL1000A - 2017+ 12 12-21-2018 12:24 AM
1000 vs. 650 jb1950 DL1000A - 2014-2016 51 12-12-2014 10:21 PM
Suzuki unveils the new V-strom 1000abs E.Ness DL1000A - 2014-2016 141 10-26-2013 09:15 PM
