New to a Vstrom, looking for advice - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 13 Old 04-17-2019, 09:35 PM Thread Starter
Hi all, I just purchased a 2012 dl1000. This is only my second motorcycle, my first being a 1998 Honda Valkyrie. I am hoping to get some advice on the best rpm to run the bike at, when best to change gears and the like. The two bikes are geared entirely different.
Also, just ordered some handlebar risers and wondering what clamps I will have to disconnect in order to install them .
Thanks for the advice
Gsrrph is offline
post #2 of 13 Old 04-18-2019, 05:00 AM
Gert's Avatar
The V-Strom comes alive when running in the upper rpms, so take care. You can short shift around 3.5K-5K rpm, to keep fuel consumption / exhaust noise in check or run above 8K rpm, to live a bit on the edge. Just as long as you ride safely. At the end of the day, it is your choice on how you want ride it and how much of a grin factor you want. Lower rpm below 3.5k may require the installation of a power commander, to enrich fueling.
In reply to the risers, it would depend on the height of the risers and whether you have to reroute cables or extend brake lines, etc. Use the search function on this site to look for risers. There are many threads on the subject.
Gert is offline
post #3 of 13 Old 04-18-2019, 08:11 AM
Webfors's Avatar
Regarding shifting/rpms, ride, experiment and find what you like best. But watch out for that torque
The handlebar clamps is all I had to undo to install my barbacks, which I suspect is the same for risers. Four bolts when you are sitting on the bike and look straight down at your handlebars. But if you're asking that question, I would recommend watching a couple youtube videos first, and make sure you put the bolts back on with the correct torque and some blue thread locker.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #4 of 13 Old 04-18-2019, 05:39 PM
Big Boy's Avatar
Welcome to the Strom Troopers!!!
I like to keep my revs around 4,000 rpms. Seems to be smoother plus it's an easy gateway to the higher revs. But as said previously, ride it and experiment to determine what you like best.
W. C. Fields
Big Boy is offline
post #5 of 13 Old 04-19-2019, 03:45 PM Thread Starter
Thanks for the advice. I have been running at around 4k and shifting around 5 so from the sounds of it, I am right where I should be. Very different from the 1500cc cruiser I used to ride. She is a great bike though and so far has done everything I have asked.
Big B likes this.
Gsrrph is offline
post #6 of 13 Old 04-19-2019, 03:53 PM
bwringer's Avatar
Make sure you explore the upper reaches of the tach sometimes, though. Let the big dog eat once in a while. It's why we ride literbikes.
Hot damn, this is a fun engine. It loves to spin. Enjoy it.
Big B and Gert like this.
bwringer is offline
post #7 of 13 Old 04-19-2019, 04:01 PM
I would go a little tighter. They seem to like it and I am sure it won't break unless you get silly. It may take you a bit to get used to it but your shifts will be happier IMO.
kfh000 is offline
post #8 of 13 Old 04-19-2019, 04:06 PM
He had a 1520cc Valkyrie previously, so the "lack of torque" with the 1000 Strom will likely bore him. Love my 97, it is faster than Hell for a cruiser, handles great for what it is too. As for shifting on the 1000 Stroms yes it is true these engines like to rev, anything under 3000 RPM is lugging that engine IMHO. I NEVER used 6th unless I was going at least 70/75 MPH, and most the time when riding in the twisty stuff I was always in 4th gear.
post #9 of 13 Old 04-19-2019, 08:19 PM
Keith Code of Superbike school told us to shift at redline. On the track sure, in real life maybe not. As some have suggested, let it run to the max occasionally.
It should leave you weak in the knees perhaps. The 650 gets real excited at the top and goes like stink. Don't need 1000 cc's to entertain me.
Gert and DonOhio45813 like this.
notacop is online now
post #10 of 13 Old 04-19-2019, 11:17 PM
Tony839294's Avatar
Welcome to the Stromtroopers. Been riding a Vee since 2008. It's become my go-to bike and it's taken me all over the USA. If you're still running stock gearing, consider lowering the ratio to 17/43 or 44 or something close. Grin factor will increase considerably and you can actually use 6th gear. Enjoy and be safe.
2012 DL1000
2014 Triumph Thunderbird Commander
1979 Suzuki GS1000L
Tony839294 is offline
2008 vstrom valuation. Stphnw8 Australia-New Zealand 10 05-29-2013 01:12 AM
My 3rd Vstrom now home. oldturtle General V-Strom Discussion 10 05-20-2013 08:48 PM
VStrom Cross-Country Trip FFGreen DL650 and DL650A - 2004 to 2011 18 11-29-2008 08:27 AM
