Gapping NGK CR8EIX plugs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 12 Old 04-15-2019, 05:29 PM Thread Starter
The manual for my 2002 V-strom doesn't even mention these plugs though clearly they can be used now...it only recommends the CR8EK and there is a gap check/adjustment procedure shown for those plugs.
My question is do the iridium plugs need to be gapped? On the box there is a picture showing a plug being gapped with a red X through it as if to say "do not gap these plugs" but no text to confirm.
My thoughts are it's pre-gapped from the factory but just thought I would confirm.
Jim Baldwin is offline
post #2 of 12 Old 04-15-2019, 06:36 PM
it's good to check the gap before installing plugs. It certainly can't hurt.
i suppose whatever the original plugs were set is appropriate.
This post has been relegated to false/fake news. Posted by one who has learned mo bettah!
post #3 of 12 Old 04-15-2019, 07:04 PM
madscrapper85's Avatar
Every iridium plug I've ever seen is pre gapped. More than likely you would damage the electrode by gapping it.
Lrobby99 likes this.
madscrapper85 is offline
post #4 of 12 Old 04-15-2019, 09:25 PM
BC Rider's Avatar
They come pre gapped. The electrode is thin so be careful when you check the gap. If you just pop a wire gauge in there you can damage it.
13 DL650
80 CX500D sold and missed
BC Rider is offline
post #5 of 12 Old 04-15-2019, 09:51 PM
bajakirch's Avatar
The manual for my '12 Wee specifically said NOT to gap the Iridium plugs.
bajakirch is offline
post #6 of 12 Old 04-16-2019, 12:56 AM
Brockie's Avatar
When you see a red circle with a 45 degree red line through an image, it means do not do this, so yes, do not attempt to gap them.
Brockie is offline
post #7 of 12 Old 04-16-2019, 07:53 AM
VERY EASY to destroy the iridium electrode! Most don't have the tools to correctly gap, and would probably do damage just checking the gap, of these spark plugs.
Unless the plug has already been damaged by hitting it on something leave them alone. These plugs can and will fire gaps that other plugs will not, so gap is not as critical.
realshelby is offline
post #8 of 12 Old 04-16-2019, 08:20 AM
enumclaw's Avatar
Leave them alone! It can indeed hurt to just check them.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #9 of 12 Old 04-16-2019, 04:16 PM
bwringer's Avatar
Agreed, don't go sticking your grubby gap tools in there. Iridium plugs are especially vulnerable, but I've seen platinum and standard plugs damaged by egregious gappery too.
Eyeball each plug to make sure it hasn't been dropped on its head, and screw it in.
For that matter, every NGK plug I've ever used has come from the factory with the correct gap. I haven't gapped a plug or even bothered to check in aeons. Eyeball and install.
STCorndog likes this.
bwringer is offline
post #10 of 12 Old 04-17-2019, 07:11 AM
Location: Boise National Forest, Central Idaho Mountains
I have never gapped an iridium plug. Run them in all 3 of my current bikes, ran them in my last 2 bikes (older Venture & yamaha 850 special)....
cavedweller22 is offline
Spark Plugs at 5K dmfdmf V-Strom Service and Maintenance Questions and Discussions 5 01-28-2017 06:52 PM
NGK CR8EIX Spark Plugs anyone using them? Captain Farkle DL650A - 2012-2016 25 04-26-2016 07:54 PM
2 cylinders = x plugs the schwartz DL650 and DL650A - 2004 to 2011 5 04-19-2013 12:28 PM
Should spark plugs look like this at 7.9k? z33tec V-Strom Service and Maintenance Questions and Discussions 11 03-25-2012 11:29 PM
