Rattling noise - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #11 of 14 Old 04-19-2019, 07:17 PM Thread Starter
Stromburg's Avatar
Is there an aftermarket air box or a modification that would quieten it down a bit? I think that even if I tried to sell it, that noise would put anyone off!
Stromburg is offline
post #12 of 14 Old 04-19-2019, 09:40 PM
blaustrom's Avatar
Don't try to change the airbox. Nothing good will come from that. Make sure the 2 rubber boots are securely connected to the throttle bodies.
Don't run the engine below 3k. If you think you must then get a boosterplug. That will make it more pleasant down to 2k.
DesertBike likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #13 of 14 Old 04-20-2019, 01:39 AM Thread Starter
Stromburg's Avatar
Ok. I've heard of the dynojet pcv. Are they similar, which of the 2 is the better option for the vee?
post #14 of 14 Old 04-26-2019, 02:48 PM
DesertBike's Avatar
I didn't know there was a name for that sound. I thought it was normal.
DesertBike is offline
iPhone only - Those that use earphones...noise cancel report Macdoc General V-Strom Discussion 7 04-23-2019 09:41 PM
2014 Vstrom 1000 Noise ???? Kubi DL1000A - 2014-2016 23 06-10-2016 05:43 AM
Engine noise on 2012 (Japan) model. stan-in-japan DL650A - 2012-2016 3 10-13-2013 09:49 PM
Engine Rattling Noise dmackinnon General V-Strom Discussion 2 07-06-2012 04:06 PM
