Got clutch/crank case cover off - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 2 Post By MAZ4ME
  • 1 Post By realshelby
  • 2 Post By cavedweller22
post #1 of 8 Old 04-13-2019, 05:01 PM Thread Starter
Location: Boise National Forest, Central Idaho Mountains
Howdy all,
I know their are some more experienced clutch guru's who have much more experience than I do with clutch issues, so here goes.
2007 Vee. Last fall I barely got her home when the stator went kaput. I have since repaired the stator/loose magnet issues and that part working perfect.
I thought I screwed up the clutch slave cylinder, but I had taken off and put back on many times since I've had this bike with no issues.
After taking the slave apart, totally cleaning the piston/chamber, put it back together, new fluid totally bled the system again, still no forward drive.
So drained coolant/oil, took off clutch cover (I did this because I could move the clutch/pressure plates through the oil filler), tried the screw driver trick manipulating clutch, it would tighten, but then loosen back to floppy clutch/pressure plates.
The 5 springs all look good, clutch/pressure plates look good, so is my next step taking off the crimped washer nut?
What is the possibility the #20 push rod has an issue?
Also, when I grab the clutch basket, it is solid - except for I can turn it (clunkily) forward & back about 1/4", is this normal?
Thank you in advance for any thoughts...
cavedweller22 is offline
post #2 of 8 Old 04-13-2019, 05:10 PM Thread Starter
Also another thought
Howdy again all,
I also forgot to add, when I pulled the clutch/pressure plates out, the flat washer was last, the wavy washer was before the flat washer... which I thought was supposed to also be a wavy washer?
post #3 of 8 Old 04-13-2019, 05:48 PM
Paging Mr. Shelby....
Big B and Motor7 like this.
MAZ4ME is offline
post #4 of 8 Old 04-13-2019, 06:02 PM Thread Starter
Whichever genius crimped the lock nut on, really made it difficult to get loosened..
post #5 of 8 Old 04-13-2019, 09:29 PM Thread Starter
Just an update... I decided to put back together and wait until I could get clutch parts, well to make a long story short, in the end, I think
the 5 bolts w/springs were causing the issue. After I torqued them down, the clutch plates tightened up.
Put her back together, oil & antifreeze, rode her...
post #6 of 8 Old 04-14-2019, 09:19 AM
I suspect that taking it apart and putting it back has corrected the alignment of the splines where the pressure plate and inner hub mate up. Hard to see the problem if you don't know what to look for.
The flanged nut is peened down at the factory and should be peened down with each installation.
There is a hardened flat washer that is the first part to go on when you start installing the clutch pack. Then the Belleville washer spring goes on top of the flat washer, with the outer edge raised. The hardened washer is there to protect the soft aluminum from the Belleville washer spring.
If you can turn the clutch basket 1/4" inch by hand, that would tell me there is a good bit of wear internally.
The 5 pressure plate springs bottom out. Hard to install them wrong. Never seen an issue from them.
Big B likes this.
realshelby is offline
post #7 of 8 Old 04-14-2019, 10:14 PM Thread Starter
The first thing I noticed was how easy the 5 bolt springs backed out. My plan is to ride & order the parts (clutch basket, bearings, washers, nut, springs, gasket although I did re-use old one with zero leaks..etc) then once I have everything.. do a rebuild..
post #8 of 8 Old 04-22-2019, 02:11 PM Thread Starter
Update
Ok, I've ridden little over 800 miles since this last "Fix"..
To date, clutch feels great, in fact, feels better than it ever has since I bought this bike last summer.
As finances increase, I plan to get a new WERKS basket and replace everything in the next couple months..
Big B and Gert like this.
Fitting Bagster Tank Cover - any pointers. lchlan DL650A - 2012-2016 0 10-20-2018 03:23 PM
Which top case designed for stock bracket on 2015 650XT Numbercruncher DL650A - 2012-2016 5 10-04-2017 10:35 AM
Removing clutch cover questions. JIMH DL650A - 2012-2016 2 04-15-2014 08:19 PM
Givi Maxia 55L Top Case SteveFoy General V-Strom Discussion 4 10-19-2013 01:59 PM
