Bike cuts off while riding!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
  • 5 Post By teevee
  • 1 Post By Demache
  • 1 Post By RockyMtnRoadRash
  • 1 Post By gopi.sandy
  • 1 Post By Rolex
post #1 of 10 Old 04-11-2019, 10:01 PM Thread Starter
gopi.sandy's Avatar
Hi all,
My 05 dl1k recently started cutting off mid ride. 67k
It's usually when I am at the lights and the bike cuts of electrically and the tach stays stuck at the same rpm while the bike is off. Turning the key on and off and on does nothing. The display light comes on after about 30 secs and the dial resets and does its motion like every time you start the bike.
I have not noticed any mechanical changes in the way the bike rides apart from this electrical thingy. The temps are always at two bars.
The worst case of this was when I was at speed and the bike just tried twice to cut off and showed f1. I did not know back then that restarted the bike cleared the error.
Any tips on where to start first?
Thanks!
Sent from my SM-G960U using Tapatalk
gopi.sandy is offline
post #2 of 10 Old 04-11-2019, 10:14 PM
blaustrom's Avatar
Check that big electric connector under the front left side fairing. See if there is any corrosion or burn marks indicating poor contact.
Was there any work done or changes made to the bike recently before the trouble started? If yes what was done?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 10 Old 04-11-2019, 10:17 PM Thread Starter
gopi.sandy's Avatar
Will do.
Did the valves a couple of months ago and changed spark plugs. that's it.
I took the bike to an offroad park 3 weeks ago where things were a bit lary. But the issue was there since before that.
post #4 of 10 Old 04-11-2019, 10:31 PM
blaustrom's Avatar
There are also a bunch of connectors behind the radiator. Did you disconnect anything there while working on the valves? Possibly one of the connectors may not be seated right?
Blau2 2014 DL1000A
post #5 of 10 Old 04-12-2019, 07:42 AM
teevee's Avatar
as always, check tightness of battery terminals. this has proven to be the source of many an electrical gremlin issue on stroms. check the battery itself as well.
V-Tom, chicago, VSrider and 2 others like this.
'08 DR650, '07 DL1000
teevee is offline
post #6 of 10 Old 04-12-2019, 07:41 PM
Demache's Avatar
Truth. My 1000 would cut out randomly when I first got it. Turns out the negative terminal was loose. Same symptoms with my friend's 650. I told him to check the negative terminal bolt and sure enough it was loose. Always check the battery terminals. It can't run without a reliable ground.
Sent from my ZTE Axon 7 using Tapatalk
Hatchi likes this.
2007 V-Strom DL1000 (current!)
Previous:
1999 Honda Shadow VT1100C (2016-2017)
2003 Yamaha V-Star 650 (2012-2016)
Demache is offline
post #7 of 10 Old 04-17-2019, 10:17 AM
RockyMtnRoadRash's Avatar
So very very very this. My strom and my bandit both love rattling battery bits loose. Check both the screwed in bit and the wire connection to the ring terminal.
V-Tom likes this.
-RMRR
'05 DL1000 - Dead at 66K miles.
Nerding it up at Wheelnerds.com
RockyMtnRoadRash is offline
post #8 of 10 Old 04-17-2019, 10:24 AM Thread Starter
gopi.sandy's Avatar
So I removed all the accessories off the battery terminals and tightened things. It's running fine for now. I'll put some miles this weekend.
Thanks all.
V-Tom likes this.
post #9 of 10 Old 04-17-2019, 12:06 PM
V-Tom's Avatar
Battery terminal connections should be the first thing checked whenever there are any weird battery or running issues on Stroms. it is easy to do and costs nothing and takes just a minute to check.
..Tom
2015 DL1000 New July 2015 160,000+ km, 100,000+ miles.
SMIDSY detailed report.
V-Tom is online now
post #10 of 10 Old 04-17-2019, 08:31 PM
Rolex's Avatar
Many many bikes have trouble with their battery terminals and the reason most people don't look at them is if it were in a car it would not start with bad terminals but on a bike it will fire up fine but give trouble later in the ride.
I'm with V-Tom, they are easy to check and a good place to start when fault finding, but really they should be checked long before a problem shows up, DO IT NOW why not.
V-Tom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
45 Countries on my Euro Trip. Bike for sale lancesulli Euro Troopers! 1 09-28-2016 09:52 PM
Bike Leaning while riding aggiengr Riding Proficiency 59 07-01-2016 11:19 AM
Looking at a V. 84Sabre General V-Strom Discussion 14 06-08-2014 02:54 AM
Full Report: CO/WY/UT SaddleSore 1000 MRV Ride Reports (Route Sheets) 0 07-24-2013 03:53 PM
My Day @ Barber Motorsport ChiGuy64 Riding Proficiency 12 06-04-2013 08:39 PM
