2007 dl1000 Questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Demache
post #1 of 3 Old 04-04-2019, 12:22 AM Thread Starter
I'm curious, about what speed do you guys shift from 5th to 6th gear?
Also, I noticed my speedometer is way off (compared to the Waze app, which is accurate in my car). Is this an easy fix? As I go faster, it shows me going quite a bit faster than my real speed-about 7-8 mph too fast at 75 mph.
87Duckfan is offline
post #2 of 3 Old 04-04-2019, 01:03 AM
Demache's Avatar
Really the only time I shift to 6th is at 65 mph and above. Maybe lower if it's really flat, but I try to keep the engine above 3000, 3500 preferred.
And yes the speedometer is notorious for being inaccurate. The odometer isn't, fortunately.
Other thing to check if you are not the original owner and not replaced sprockets yourself is check if it's at the using the stock 17/41 tooth sprockets. Speed is measured off the front sprocket, so a change will change accuracy wildly. If they are not the stock sizes, you will need to either swap them back to stock size or buy something like a SpeedoDRD to calibrate the speedometer. Yours sounds within a reasonable margin of error though so it's probably fine.
Sent from my ZTE Axon 7 using Tapatalk
Big B likes this.
2007 V-Strom DL1000 (current!)
Previous:
1999 Honda Shadow VT1100C (2016-2017)
2003 Yamaha V-Star 650 (2012-2016)
Demache is offline
post #3 of 3 Old 04-04-2019, 10:19 AM
Big Boy's Avatar
Here's the SpeedoDRD device if you want to correct you speedometer. But be warned that you have to remove the entire top of the bike to access the coupling to insert the DRD. Pics Below.
Here's where I bought mine>>> https://www.amazon.com/SpeedoDRD-SDR...1S0VXKBHFYTGMQ
W. C. Fields
Big Boy is offline
What price should I ask for my 2007 DL1000? kawazukiman DL1000 from 2002-2012 8 07-13-2015 10:27 AM
'05 DL1000 pre buy questions Anton Chigurh DL1000 from 2002-2012 7 03-30-2011 11:50 AM
06 DL1000 Questions ilsrwy33 DL1000 from 2002-2012 13 07-18-2008 08:46 PM
