Valve shim size? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-02-2019, 05:24 PM Thread Starter
CoastyAV8R's Avatar
Valve shim size?
I'm going to check my valves and I wanted to have a box of shims on hand because this is one of 4 bikes I have with shim under bucket adjustment and my local dealer is awful at having anything in stock. I see the normal thickness is 2.6mm to 2.9mm but I wanted to confirm the outside diameter is 9.48 mm and not one of the other sizes that are available (7.48, 8.90).
Thanks
2008 V-Strom 1000
CoastyAV8R is offline
post #2 of 6 Old 04-02-2019, 05:54 PM
9.48 mm is correct.
realshelby is offline
post #3 of 6 Old 04-02-2019, 06:21 PM
nvr2old's Avatar
Just did my 2018 1000 and all the shims I needed ran between 275-290 thickness.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 6 Old 04-02-2019, 10:40 PM
larolco's Avatar
I've had to use a bit smaller than that (down to 265ish) but that range sounds about right. You can probably swap shims between valves as well and only need at most a couple new ones.
Where I live, there's a shop on CL who advertises shims for sale. Won't help you, though.
DRZ400SK17
larolco is offline
post #5 of 6 Old 04-02-2019, 11:28 PM Thread Starter
CoastyAV8R's Avatar
Not that I wouldn't mind up a trip to your neck of BC to pick up those shims, I'll just order a box between 250 and 300.
Thanks for the help gentlemen!
2008 V-Strom 1000
post #6 of 6 Old 04-03-2019, 01:59 AM
Highwayman2016's Avatar
I got a whole box of assorted shims from https://www.rockymountainatvmc.com/
2014 650 Strom
Highwayman2016 is offline
Vee2 valve shim kit Jim Jones DL1000A - 2014-2016 11 01-04-2018 04:13 PM
Valve Adjustment vulcanbike DL650 and DL650A - 2004 to 2011 57 12-22-2015 01:43 PM
What size are the valve shims on the new motor? HS-LD DL650A - 2012-2016 2 07-08-2013 09:39 PM
Valve shim chart cc cruiser Maintenance, Tech and Products. 1 07-07-2013 09:13 PM
Valve Shim Spreadsheet here for download Tollster V-Strom Service and Maintenance Questions and Discussions 1 07-03-2008 02:19 PM
