Speedometer odometer not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 04-01-2019, 08:24 AM Thread Starter
Marco Materia's Avatar
Hi guys, i have a Vstrom k2 , i change the indicator whit a new indicator a led, but now my cluster dont work, all the light are ok, but Speedometer odometer Watch indicator of fuel dont working , all the fuse are ok.
Marco Materia is offline
post #2 of 2 Old 04-01-2019, 08:38 PM
bwringer's Avatar
You might have accidentally pulled the connectors loose.
There's a cable coming from the back of the speedo unit. Push this connector in and make sure it's locked in.
Follow the cable down until you find the connector to the wiring harness and make sure it's plugged in all the way. Make sure the connector is not corroded. Sometimes this connector gets dirty and the metal terminals corrode.
bwringer is offline
Speedometer problems? peedee DL650 and DL650A - 2004 to 2011 9 04-02-2017 08:58 PM
Weird speedometer problem sidleedsrugby Euro Troopers! 6 09-28-2015 07:05 PM
Speedometer or Speedometer Sending unit? madchap DL650 and DL650A - 2004 to 2011 2 08-06-2015 08:33 AM
16 Tooth Countershaft fixes Speedometer! realshelby DL650A - 2012-2016 115 08-07-2014 12:19 PM
Installed Rostra cruise control now speedometer doesn¯t work Rick54 DL650A - 2012-2016 12 10-04-2012 08:51 PM
