2003 DL1000 Brake Issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By realshelby
post #1 of 4 Old 03-20-2019, 03:18 AM Thread Starter
hoggdoc's Avatar
Location: The Great Northwest (Southwest Washington State)
Send a message via Skype™ to hoggdoc
Question 2003 DL1000 Brake Issue
I purchased a 2003 V Strom 1000 last year. One of the first thing I did replace the rear brake pads. I serviced the caliper and verified it was in good working order. The issue is there is very little movement of the brake pedal and it takes a lot of force to create any kind of braking.
The brake does seem to work better if I build some heat in the pads. I'm wondering these are typical characteristics for this bike. My thoughts are the pads too thick and the friction materials are super hard and require heat to work.
Any thoughts will be appreciated.
[FONT="Comic Sans MS"][SIZE="4"][B]2003 Zuki V-Strom 1000[/B][/SIZE][/FONT]
hoggdoc is offline
post #2 of 4 Old 03-20-2019, 04:31 AM
As far as the movement is concerned, the hydraulic brake system is self-adjusting. So regardless of the thickness of the brake pads, lever initial position and lever travel will always be the same. That is, assuming that you have the original master and slave cylinders. If somebody messed with either, then the amount of fluid the master puts out might not be balanced with the amount of fluid the slave needs, and may affect lever travel. You may want to check the part numbers on master and slave cylinders to see if they're original.
As far as brakes fading or not, there are several types of brake pads available. The same applies to the rotors. There is no ideal material for all circumstances. Some rotors only perform when dry, others also have good performance when wet. Some brake pad material works reasonably well in all circumstances, other brake pad material might need a bit of heat build-up to work effectively. Those are great for racing, not so much for street use. My thinking is that the PO thought better than Suzuki and equipped your bike with racing rotors/pads instead of a combo for street use. See if you can find manufacturer and part numbers on the pads and discs, and what type of material they're made of. That may tell you whether what you describe is normal behaviour or not.
I was going to suggest you swap everything (all rotors and pads) for OEM, but I just bought that combo for the upcoming major service, and it's near 500 dollars or so, so not something to try as part of your initial troubleshooting efforts.
(Edited to add: The brake has been properly bled, not? If the brakes feel spongy, then there may be air in the system somewhere.)
BackPacker is offline
post #3 of 4 Old 03-20-2019, 09:27 AM
All V stroms have a rather dead feel to the rear brake. Yet you might be surprised at how much braking force they are actually doing. Because they kind of cause the reverse of brake dive, when using only the rear brake, you don't get the same effect. Different pads can help, even proper bedding of the pads helps. But they are a bit vague. Practice a couple slow speed stops, even when the rear wheel locks you won't get the feel of hard braking. Not so different from other bikes, but I would say the brake pedal does require more force than I would like.
Gert likes this.
realshelby is offline
post #4 of 4 Old 03-20-2019, 04:15 PM
Rolex's Avatar
Strom brakes are often described as "wooden"
Have you lubricated the pedal pivot point ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
2012+ 650 rear brake pad replacement JorgeLuis DL650A - 2012-2016 20 11-28-2018 01:47 PM
The Original SV Racing Parts, 4 Piston Brake Caliper Adapter Bracket Upgrades SV Racing Parts SV Racing Parts 126 09-24-2017 05:15 PM
2003 dl1000 starting issue tallstrommer DL1000 from 2002-2012 3 09-10-2014 01:02 AM
Nissin Radial Front Brake Master Cylinder for DL650 and DL1000 SV Racing Parts SV Racing Parts 19 09-27-2012 06:47 PM
