front wheel not symmetrical ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Yarz1
post #1 of 4 Old 03-11-2019, 10:10 PM Thread Starter
I always learn something when I work on my motorcycles. This I found interesting, having never known it before.... I'm sure you all knew this. But this just goes to show you that you can, in fact, teach an old dog new tricks.
My wheel bearings took longer to arrive than anticipated. My front wheel was off for a couple weeks, getting moved around the garage as it kept getting under foot. When I reinstalled it with the new bearings, I noticed that the left brake caliper went on seemingly tight. But it went on OK. Then I discovered that the right brake caliper refused to go on and line up for the bolts. It was too far to the right to get past the bolt slots on the fork tube. Hmmm, the axle and the spacer were in place fine. As I tried to figure out what the heck was going on, my eye caught sight of the direction arrow on the tire. Ooops, I had inverted the wheel and was trying to install it wrong. The wheel was essentially backwards. Once I took it out, spun it around and installed it properly, everything slid together smoothly. I never studied the front wheel in enough detail before to know it can only go on one way. I always thought the front wheels were symmetrical -- but I did always pay attention to the directional arrow, except this time. I guess Suzuki built in a safety feature for some of us sometimes distracted unattentive DIY mechanics.
Gert likes this.
Yarz1 is offline
post #2 of 4 Old 03-13-2019, 08:58 PM
bwringer's Avatar
On most bikes (like the DL650) you have a speedo drive on one side that also helps you stay oriented.
Once it's off the bike, it really is a little hard to tell which way a DL1000 front goes. Years ago, I put a teensy arrow near the center of my Vee's rotors with a paint pen.
On other bikes, I've encountered tires some idiot in a shop installed backwards a depressing number of times.
bwringer is offline
post #3 of 4 Old 03-13-2019, 10:34 PM
Hard miles's Avatar
On my 2009 Vee it does not matter which way the front wheel is placed. Both sides are symmetrical. When the tire starts getting scallop I install it the other way.
Hard miles is offline
post #4 of 4 Old 03-14-2019, 01:17 PM
bwringer's Avatar
It's the exact same wheel on 2002-2012 Vees, so it sounds like I and a few others may have been making an incorrect assumption that the wheel needs to spin in a certain direction.
Hmmmm.... digging further, the rotors, bearings, and both seals are the same, and the spacer between the bearings is not directional (one most bikes, these parts vary side to side, so the wheel is directional).
Whether the wheel has any offset, I don't know. But from your experience, it sounds like it doesn't.
The one possibly significant issue is that brake rotors never wear evenly, so when you flip the wheel around, the brake pads will need to bed in or wear to match the rotors.
I'm wondering if brake drag explains what the OP is experiencing. Or it sounds more like the caliper slider pins are sticky, or just ended up in slightly different positions; the calipers have a significant amount of "float" side to side to accommodate wear.
bwringer is offline
DL1000/650 Front Wheel Removal MightyShep Maintenance How-to 53 03-18-2018 10:26 PM
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 06:23 AM
2012+ DL650 front wheel removal NeverSatisfied Maintenance How-to 2 07-12-2014 02:13 PM
Mud locks front wheel per_1999 DL650 and DL650A - 2004 to 2011 8 04-14-2008 11:20 PM
