I put a set of these $28 Metal Foot Pegs in Black on my 02 VSTROM 1000, I don';t notice vibration and they sure work for standing. The vendor was very easy to work with and has multiple color options. I had to reuse the stock pins and springs and I had to do a little filing on the brackets flashing lines to get a smooth fold operation. As Always YMMV.
"The only dumb question is the unasked question" - Anonymous
Sponsored Links | |||
i got a set of DR pegs from someone here on the forum, I don't keep track. They feel very good and secure. A bit smaller that the DL factory pegs but I like 'em!
Originally Posted by bigjohnsd
View Post
2007 Vee with too many farkles and 50k+ (s)miles
Originally Posted by DesertBike
View Post
Lots to like here, but those studs (really, set screws) seem very aggressive. Have you had a problem with that? Seems like your boot soles would get chewed up in short order.
Has anyone done both Goldwing pegs AND a footpeg lowering kit?
I just installed the Adventuretech footpeg & control lowering setup yesterday. I don't believe it creates any new clearance problem - presumably, the "asphalt detector" nubbin on each footpeg would still do its job.
I'm assuming the same would be true even with the extra 3/4" drop of the Goldwing pegs. However, I'd have to adjust shifter & rear brake pedal height, and I'm not 100% sure there's enough range available in the respective linkages.
On the DL1000 you have that rear brake pedal return spring. The Adventuretech lowering kit includes a metal clip to make the reach. But, I'd need an even longer clip to go another 3/4".
Have been riding with the Adventuretech footpeg lowering kit for a while. It's pretty nice. 1" lower doesn't sound like a lot, but made a big difference in comfort. Combined with raising the bars (installed 3.5" Rox risers a few months ago) it is now far more comfortable to stand up, as well.
FWIW the eBay footpegs above seem to be based on the Fastway Evolution III footpeg: https://promotobillet.com/fastwaypro...22-5-001-6031s
Your call whether the Fastways are worth $139. They do come with an extra set of cleats, so you can suit your traction needs & decide how much you want to tear up your boots. A bigger difference is the Fastways are made of stainless steel, vs. aluminum for the direct-from-China version.
I'm not so sure I would want super-strong, stainless steel footpegs. I've broken enough things that I've come to appreciate bits that will snap off or bend, rather than break the much more complicated- and expensive-to-replace thing they're attached to.
Does anyone know what year Goldwing footpegs are compatible with Vees? I want to dig around for people on Goldwing forums who are selling their stock footpegs, but I don't know what model years will work.
Why hasn't Suzuki fixed their crap pegs.
I love my sw-motech pegs... could stand all day with confidence.
Two wheelz for realz!
'18 DL1000XT
View Post
I just ordered a set of PivotPegz. Direct from the manufacturer. They were having a deal where you get the toppers for $10 off, and a free "service" kit so I figured heck, why not.
Not cheap, no, but looks like good stuff.
Footnote re: ground clearance. I don't think it will be a problem, or rather other things will be the problem not footpegs. Recently I hit a dip coming in to a parking lot that made a terrible noise and felt wrong. Turns out the corner of my skid plate got some metal shaved off. It sticks down & right farther than my footpegs with the suspension under compression.
I had adjusted the rear shock for "correct" sag using the well-known guide at VSRI but I guess I will add a turn or two. I really would rather not have my skid plate drag again. It's alarming & will eventually weaken the skid plate.
Sponsored Links | |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
OEM Case guard bolted Highway footpegs.,.Ideas | Paul13DL | DL650A - 2012-2016 | 3 | 06-10-2016 12:13 AM |
Lowering footpegs | mattc183 | General V-Strom Discussion | 4 | 05-27-2013 02:25 PM |
Footpegs | WiredDriver | Maintenance, Tech and Products. | 5 | 07-03-2012 10:38 PM |
How do I raise passenger footpegs? | Corkus | V-Strom Modifications and Performance | 13 | 07-12-2010 08:40 PM |
Posting Rules | |
