Rear Swingarm bearings DL1000 K2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-10-2019, 09:57 AM Thread Starter
Hello, hope someone can help. I've been advised that the swingarm bearings need replacing. Having looked on several parts sites the diagrams seem to suggest that there are 4 bearings required of two different sizes (two on each side) but some sites advertise bearing kits which seem to show 2 bearings and 2 bushes? Before I dismantle the swing arm, I'd like to have the spares ready. Can anyone assist me in explaining exactly how many bearings are needed and/or better still have any pictures of a dismantled swing arm bearing area? Many thanks
stevee112 is offline
post #2 of 7 Old 03-10-2019, 10:27 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
https://www.suzukipartsnation.com/oe...r-swinging-arm
There is one pair of swing arm bearings with acompanying spacers. One set for each side.
The cush rod bearings are for the suspensions linkages. If your swing arm bearings are worn I suggest checking these bearings as well.
The diagram is not clear because it does not show the placement of cush rod (suspensions linkage dog bones) very well.
richlandrick is online now
post #3 of 7 Old 03-10-2019, 11:17 PM
Rich, do you package the bearing set for the shock linkage? I have a spare linkage set that needs a referb before i install it.
It's one of those things that otta be looked at every 100K or so, no?
post #4 of 7 Old 03-10-2019, 11:48 PM
it's not the kind of thing we do. i would check a local bearing supply store and get double sealed bearings.
post #5 of 7 Old 03-11-2019, 12:12 AM
Highwayman2016's Avatar
https://www.cheapcycleparts.com/oemp...r-swinging-arm
2014 650 Strom
Highwayman2016 is offline
post #6 of 7 Old 03-13-2019, 06:11 AM Thread Starter
Thanks to you all for your replies, I think I will replace both sets of bearings.
post #7 of 7 Old 03-13-2019, 09:12 AM
Your welcome. There are bearings at the bottom of those dog bones as well. So that would be three pairs of bearings.
Swingarm bearings and bushings qixilver DL1000 from 2002-2012 4 03-28-2010 01:13 AM
