Usual lighting fault - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-07-2019, 12:55 PM Thread Starter
Gruffalo1973's Avatar
Headlights not working on a bike I’m buying. I have stripped and cleaned starter switch. Checked all terminal blocks. All seem fine and have good continuity. My problem is I’m not getting any power to the 2 fuses in the fuse box. Any ideas and help appreciated
Gruffalo1973 is offline
post #2 of 5 Old 03-07-2019, 02:52 PM
blaustrom's Avatar
Is your main 30A fuse blown?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 5 Old 03-07-2019, 03:53 PM Thread Starter
No. Everything else is working. Bike starts and rides. All gauges work.
post #4 of 5 Old 03-07-2019, 05:08 PM
Grimmer's Avatar
Many times the fuse block uses snap in terminals. Is there a chance that those terminals have slipped out of the plastic fuse box retainer and your fuses are not engaging both of the metal terminals anymore?
Grimmer is offline
post #5 of 5 Old 03-07-2019, 05:09 PM
Grimmer's Avatar
Otherwise, see if you can unbolt the fuse block and look at the back of it. Maybe some wires have broken, burned, etc...
Grimmer is offline
Dl 650 vstrom 2008 c12 fault Bandit1974 Stromtroopers - New member introductions 6 07-31-2018 12:16 PM
2012 ABS code 42 fault MNrider DL650A - 2012-2016 0 07-24-2018 04:08 PM
The Dreaded C-28 fault! P_Smith DL650 and DL650A - 2004 to 2011 2 04-02-2018 09:38 PM
Givi E55 Topcase with Admore LED lighting kit dkuperberg V-Strom Modifications and Performance 3 12-20-2010 01:36 PM
HID lighting for my DL1000 Doc Steve2 General V-Strom Discussion 3 10-06-2010 01:20 PM
