Starts, runs, headlights on - but no instruments or turn signals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 12 Old 03-07-2019, 10:57 AM Thread Starter
Farkle Purchasing System
DesertBike's Avatar
Well this is just weird. I was almost on my way to work this morning when I noticed that NOTHING on the instrument panel was working. Not the speedo, not the tach, not the odometer/fuel gage/temp gage panel, none of the indicator lights, nada. Turn signals weren't activating.
Headlights were on. I didn't have time for a complete diagnosis before work, but it does seem that starting is completely normal, kickstand switch is working fine, as is clutch switch and fuel pump (else I probably couldn't get it started/it wouldn't run). I got down the block before I noticed something wasn't right, because shifting and acceleration were also unaffected.
Bike worked fine last time I rode it (last Saturday). Started up again in my garage, voltage indicator was a happy green at idle, so I think the battery & charging system are just peachy (but again, didn't have time for a full diagnosis).
I'm not sure where to even start looking. I've found a few old threads about dead electrics, but they also had starting problems or headlights didn't work. Help??
2007 Vee with too many farkles and 50k+ (s)miles
DesertBike is online now
post #2 of 12 Old 03-07-2019, 12:04 PM
blaustrom's Avatar
Likely a problem with a corroded or burned connector. I think you model has a big connector on the left side inside the fairing. Check that one and any of the ones that you can get to around the radiator. see if you see and discolored/ burned contacts. Good luck!
V-Tom, Brockie and DesertBike like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 12 Old 03-07-2019, 12:28 PM Thread Starter
DesertBike's Avatar
I put in LED H4 replacements a few months ago but yeah, I understand it's common for that connector to be partially fried by Suzuki unwisely shoving headlight power through it. I'll have a look this afternoon.
post #4 of 12 Old 03-07-2019, 04:41 PM
WildDoktor's Avatar
Wow...that's super odd! I'm subscribing just to hear what you eventually find the root cause to be! I have no useful input beyond that. :-)
DesertBike likes this.
WildDoktor is offline
post #5 of 12 Old 03-07-2019, 05:36 PM
Grimmer's Avatar
Blown Fuse?
Grimmer is offline
post #6 of 12 Old 03-07-2019, 07:07 PM Thread Starter
DesertBike's Avatar
Well, that's not good at all. The 15A "Signal" fuse was blown. No idea what caused it.
I haven't messed with anything electrical in months, so, weird. I'll look at the multi-pin connector up front later today.
post #7 of 12 Old 03-08-2019, 08:11 PM
bwringer's Avatar
Yep, betchya it's that stupid connector on the left.
See, Suzuki in its infinite wisdom ran a bunch of stuff and a bunch of electricity through a nine-pin connector with undersized pins.
Then they decided to just leave it open to the elements. No sealing around the wires or the connector shells. Tucked out of sight in the dark where all kinds of muck and moisture can get at it and do their evil work.
And lo it comes to pass; at some point every V-Strom's headlights go mysteriously dark. And/or the instruments and signals play up.
It's a longstanding Suzuki tradition. For all the incredible engineering and intelligent design that goes into their bikes, some of their electrics have been pants-on-head stoopit for five decades. Every Suzuki has at least a couple of idiotic booby traps like this buried in the wiring.
Big B and DesertBike like this.
bwringer is offline
post #8 of 12 Old 03-08-2019, 10:02 PM
tucsonray's Avatar
So I had the EXACT same problem. I ended up fixing it by replacing my ground cable and cleaning the sh#t out of the contact on the engine. Has not blown since.
However this is the first I have read bout that connector. That may be the real culprit. Ill have to check that out on my bike
It may be worth at least cleaning up your ground cable at both ends and see if that helps. Its fast and cheap/free.
I the meantime get a box of cheapo 15 amp fuses to keep with you until you figure it out
tucsonray is offline
post #9 of 12 Old 03-09-2019, 12:54 AM
MontanaGuy's Avatar
Sometimes fuses just like to say bye bye on their own for no reason. Carry fuses and check connectors, and maybe it was the gremlin.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #10 of 12 Old 03-09-2019, 10:37 AM Thread Starter
DesertBike's Avatar
As with carrying a full-size spare that you keep properly inflated, I suspect that carrying extra fuses prevents blown ones in the manner of a talisman.
I now have 4 spares (hey, they're Mini, takes basically zero extra space!), thus guaranteeing I shall never blow a 15A fuse again.
That forward multi-pin connector (mine has 14, not 9) was kind of a PITA to get disconnected without breaking it, but gentle pressure with a medium-sized flat blade screwdriver & careful tugging will do it:
Looks like mine isn't old enough, and I haven't used hi-beams often enough, to fry it. Other side is similarly healthy-looking, but was too much of a PITA to photograph.
Since I switched to LED headlamps around Xmas, I should be OK indefinitely on that front.
That connector does have a big ol' rubber boot on it - presumably Suzi felt it was good enough to ensure draining water would tend not to drip in from above, or following the upper cable run. But it really should be a Weatherpak type connector! There is nothing but luck stopping a big splash from below from shorting multiple connections at once.
I'm almost annoyed enough to rewire that sucker with a proper weahterproof connector. It would cost maybe $20 in parts & shipping, and I have a Molex tool that makes beautiful terminal crimps. Aptiv 54201456N (https://www.mouser.com/ProductDetail...0C5l9orYBhY%3D) ought to do it.
Engine ground is worth a look & cleanup, but it'll wait until the next time I need to remove the front sprocket cover.
I rode to work and back yesterday with no further shenanigans occurring. Whatever it is that made the fuse blow, doesn't seem to be chronic.
Starts & runs fine when cold, engine starts to misfire when warm mushu DL1000 from 2002-2012 10 06-18-2018 11:42 AM
Converting any 2-Wire turn signal into Running + Turn Signal thepaleobiker General V-Strom Discussion 40 04-26-2018 11:47 PM
Keeping both LED and stock turn signals, any precautions? Teskio General V-Strom Discussion 10 05-08-2015 09:14 AM
V-Strom Gathering East - May 15-18 2014 fire fox Events 339 06-09-2014 08:58 AM
Spring 2013 Gathering at Ironhorse MC Lodge May 17 thru 19th Billclel2002 Events 195 06-15-2013 10:15 PM
