2 Cooling fans? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 23Likes
post #1 of 12 Old 03-06-2019, 12:19 PM Thread Starter
2 Cooling fans?
I'm redoing my entire cooling system. I have a second fan. I have installed a switched override for the fan. The radiator looks to have the space and tabs to mount a second fan with some easy mos for a 3rd tab (my horn is mounted somewhere else). The second one would be manually controlled.
Ya or na?
I think im paranoid.
I think i'm covered. I can turn the one on if the sensor fails to turn it on. hmmm
DesertBike likes this.
Cold Neck is offline
post #2 of 12 Old 03-06-2019, 12:26 PM
Lrobby99's Avatar
I always thought my k6 ran pretty cool, rarely over 3 bars.
Just for fun I replaced the coolant sensor with TS206 which has a lower temp fan setting compared to stock.
Lrobby99 is offline
post #3 of 12 Old 03-06-2019, 01:19 PM
Demache's Avatar
I would say no. It runs cool enough with one, and I don't think fan or sensor failure is a common enough issue to worry about a backup. It largely only runs when the bike isn't moving fast enough to cool passively anyway.
2007 V-Strom DL1000 (current!)
Previous:
1999 Honda Shadow VT1100C (2016-2017)
2003 Yamaha V-Star 650 (2012-2016)
Demache is offline
post #4 of 12 Old 03-06-2019, 01:19 PM
A second fan would only be a "good" thing if maybe you rode in a lot of mud or sand where you were working the engine hard and the extra fan might keep it from overheating. Don't know of that ever happening. And I for sure don't want to be paddling a Strom through gooey mud or soft sand. You will probably be needing to take a break yourself before it gets hot........
If the cooling system is in good shape, these bikes can endure 100+ degree stop and go traffic and not over heat. I know that for a fact.
realshelby is offline
post #5 of 12 Old 03-06-2019, 01:37 PM
trapperdog's Avatar
I looked into adding another fan when I was running cone courses with mine. Should be easy enough to do with slight modifications, however I don’t think the existing wiring will carry the extra load of a fan. I had planned to put the new fan on it’s own switched circuit with a switch, relay and lamp. Even when properly tuned and with a well cleaned cooling system, some of the DL’s ran hot. I ended up using piggyback fuel management systems which kept the temps in line, 2-3 bars instead of 3-4 bars. Make sure your radiator fins are free of debris and open (not bent over)
Big B and DesertBike like this.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #6 of 12 Old 03-06-2019, 04:53 PM
Farkle Purchasing System
DesertBike's Avatar
Not worth the effort IMO. As Realshelby says, even in our scorching desert summers and stop-n-go traffic I've never had an overheating issue on my K7.
Well, not the bike overheating. Me overheating, that's a different story!
2007 Vee with too many farkles and 50k+ (s)miles
DesertBike is online now
post #7 of 12 Old 03-06-2019, 05:14 PM
Sounds like a solution in search of a problem.
1.5 hours inching along in 105-degreeF temp on I-57 in July, '17. Ambient temp gauge read 120. My DL1K fan never came on not once, and the temp gauge never went about 1/2 way.
You do realize you can't possibly plan for every single contingency.
But if you have your bike's cooling system on your mind, and seeing how your profile says "'02 DL1000", I'd be checking/replacing hoses,, pertinent seals and gaskets, thermostat, water pump, coolant, and pressure-testing the cooling system before any long trip in the heat.
But hey...that's just ME.
MAZ4ME is offline
post #8 of 12 Old 03-06-2019, 07:36 PM
V-Tom's Avatar
Ya or na?
Are you an engineer?
Engineer credo: "Just because it ain't broke doesn't mean it can't be fixed."
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #9 of 12 Old 03-06-2019, 11:44 PM Thread Starter
Thanks for the reply's. Every hose, seal etc... is being replaced due to age/mileage- not a failure.
I looked at my new radiator (old one was is bent but not leaking ) and realized there is space for it. Running a relayed switch blah blah would be easy to do.
I figure if it was needed the engineers would have...or maybe not. My Duc ran hot even w/manual switch and turning on BEFORE it got warm in traffic. so that sorta explains why my mind went there.
My cooling system has worked fine. Seemed solid to me. I'm reassured that it's fine for other's also. Thanks again!
I'm trying to freshen up the old bike head to toe this winter. I'm trying to minimize mid season BS because I was unwilling or unknowing to take action now.
I find repair wrenching is not fun when it cut's into riding.
bikeflyer and DesertBike like this.
post #10 of 12 Old 03-06-2019, 11:49 PM
WildDoktor's Avatar
Man...you ain't kidding!! Be sure to check your chain, like I didn't!
Cold Neck likes this.
WildDoktor is online now
When to replace cooling system hoses Cal Scott Maintenance, Tech and Products. 50 05-29-2018 01:59 PM
Hybrid Veskimo Cooling System realshelby General V-Strom Discussion 5 08-17-2016 01:29 PM
cooling fan question Yarz1 DL1000 from 2002-2012 5 05-05-2016 02:09 PM
Cooling fans jmackd1 DL1000A - 2014-2016 1 03-24-2014 09:53 PM
Temperature in Sydney CHINOTAKER Australia-New Zealand 51 08-14-2012 08:43 AM
