Decreasing cold idle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By trapperdog
post #1 of 6 Old 03-04-2019, 11:31 PM Thread Starter
Stromburg's Avatar
Gday fellas. Is there a way of decreasing the cold idle speed?
Stromburg is offline
post #2 of 6 Old 03-05-2019, 12:52 AM
bwringer's Avatar
Idle adjuster is on the left. It looks like a Philips head screw on a wee bracket bolted to the frame.
bwringer is offline
post #3 of 6 Old 03-06-2019, 12:43 AM
trapperdog's Avatar
Are you referring to the overall idle speed or the fast idle speed when starting the engine cold? If the former, refer to bwringers reply. If the latter, check out https://www.vstrom.info/Smf/index.php/topic,7512.0.html.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #4 of 6 Old 03-07-2019, 12:07 AM Thread Starter
Stromburg's Avatar
Thanks, yes I was referring to the fast idle speed. Cheers.
post #5 of 6 Old 03-07-2019, 12:16 AM Thread Starter
Stromburg's Avatar
Wow, that's complicated! I wanted to lower the fast idle, I think the factory setting is too fast. Does anyone else agree?
post #6 of 6 Old 03-07-2019, 10:57 AM
trapperdog's Avatar
It’s pretty easy once you’ve done it a time or two. Somewhere in the sevice manual there is a chart stating what the rpm’s of the fast idle vs ambient temperature should be. Might even find it online. If yours is out f sorts, you could just lift the rear of the tank, Mark the screw with nail polish for reference and turn the screw a tad. Has to be done with a cold engine and you only have a couple of seconds
Gert likes this.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
3000+ rpm idle on cold start kevinrf DL1000 from 2002-2012 4 08-26-2017 02:42 PM
Cold start - no high idle problem ahtoxa11 DL650A - 2012-2016 2 05-06-2017 10:03 PM
Idle speed when cold tenny80 V-Strom Service and Maintenance Questions and Discussions 6 01-27-2015 12:51 PM
Cold Start Idle jsmithy V-Strom Service and Maintenance Questions and Discussions 11 02-28-2014 05:20 PM
Hard starting slow Idle when cold. T-ville Trooper DL650 and DL650A - 2004 to 2011 6 04-05-2013 02:30 PM
