Rebuild after broken chain and fire - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 107Likes
post #1 of 123 Old 11-04-2018, 12:12 AM Thread Starter
WildDoktor's Avatar
It has begun! @teevee donated a rear shock and a guy at work donated a 530 chain, and I finally got out of my funk, so I started tearing into it today.
First order of biz was to make sure no wiring was damaged by the fire. Rear wheel off, bad chain re-broken and removed, and inspection reveals no damage to wiring! Sweet!
Next job, remove the tank and have a look around. Much easier than I imagined. But, um, yeah...there's a weed poking out the (apparently modded by the PO) airbox. Really hope there's a k&n in there like was promised, since I have the cleaning kit...and I bet it's filthy! Yes on both counts. :-)
And, since I'm in here, I might as well replace the rear shock from @teevee (thank u so much!). Just 4 bolts; looks fairly simple. And...it was! New-to-me rear shock now installed and torqued.
I still have much to do, but it sure feels good to have gotten started.
Sent from my SM-N920V using Tapatalk
WildDoktor is offline
post #2 of 123 Old 11-04-2018, 01:44 AM
larolco's Avatar
Well, you need an new airbox. That's for sure. Or, I guess, you could seal up those holes.
That air filter is, um, disgusting. Looks like it might be a K&N but can't be certain. I don't remember what a stock filter looks like. Certainly needs cleaning though. I wonder why the previous owner did that. Must have had a problem he thought more air could fix. Seems bizarre; most people find these bikes run too lean.
Enjoy the rebuild. I'm in the midst of my own. I consider it a "bonding" experience. I hope your experience is similar.
DesertBike and WildDoktor like this.
DRZ400SK17
larolco is offline
post #3 of 123 Old 11-04-2018, 02:14 AM
Gert's Avatar
Gert is offline
post #4 of 123 Old 11-04-2018, 09:58 AM
WOW sure hope nothing made it's way into the top end from looking at that air filter, if the airbox wasn't clean below the filter, you are likely gonna have a bad engine in the near future.
WildDoktor likes this.
post #5 of 123 Old 11-04-2018, 10:26 AM
Yes, what BigB said. I would like to see a pic of what it looks like UNDER the air filter.
K&N filters are actually quite good at protecting engines when they are this dirty, so if it was sealed around the edges it could be just fine behind it.
realshelby is offline
post #6 of 123 Old 11-04-2018, 10:58 AM Thread Starter
WildDoktor's Avatar
Don't have a pic, but I thought the same thing and dreaded lifting that filter for fear of what I would find. What I found was a pristine, perfectly clean airbox. Thanks again, k&n! :-)
Big B, notacop and DesertBike like this.
post #7 of 123 Old 11-04-2018, 11:12 AM
That old shock, Sasquatch can make better than new for a reasonable cost.
Adventure Power Sports, LLC
Big B and WildDoktor like this.
post #8 of 123 Old 11-04-2018, 11:21 AM Thread Starter
WildDoktor's Avatar
Yeah, I'm actually saving up to get both ends done by him.
notacop likes this.
post #9 of 123 Old 11-04-2018, 08:21 PM Thread Starter
WildDoktor's Avatar
Clean! I've personally never seen a k&n that dirty before; probably because I've bought all mine new and kept them clean. :-) I had to dig junk out of every single pleat on the dirty side of this one *after* using the cleaner on it! Sheesh. Well, it'll get oiled up before it goes back in, and be good as new.
Big B likes this.
post #10 of 123 Old 11-04-2018, 10:02 PM
Kurtk's Avatar
Your going to love your ride when finished.
Kurtk is offline
Broken chain, broken bike WildDoktor General V-Strom Discussion 34 03-06-2019 09:35 PM
