Fuel pump whining 2012 100 adventure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 10-27-2018, 10:21 PM Thread Starter
I am experiencing the high pitch whining from fuel pump. No issues with performance at all. I have read many threads about the high pressure filter and by-pass fix. I do not want to do the by-pass. What are my options. I have the tank off and ready to pull the pump assembly. Is the high pressure filter replaceable? Any possibility its the lower fuel filter which is replaceable? I see prices around $200 for a filter and $20 for a filter. I do not think its the fuel pump since there are not running issues. I would just replace both since I'm in there.
steevestrom is offline
post #2 of 14 Old 10-27-2018, 10:48 PM
STCorndog's Avatar
The HP side is likely causing the whining, the LP is a cleanable sock. Pretty easy to R&R both of them, just pay attention to how the fuel pump and fuel sending unit come apart.
I did not want to do the bypass either, but many have without issues.
STCorndog is offline
post #3 of 14 Old 10-27-2018, 11:04 PM Thread Starter
Thank you! I'm getting conflicting info about whether the high pressure filter is replaceable. Some say you have to replace the entire fuel pump. I will be checking with my dealer to find out. I don't mind a few hundred after 6 years, just don't want to spend $800 plus for a new fuel pump if not needed.
STCorndog likes this.
post #4 of 14 Old 10-27-2018, 11:26 PM
STCorndog's Avatar
Well, my DL1000 was a 2007 but I think it is the same. It is replaceable. It was spendy though...about $200 for OEM if I recall.
BTW - there is a flow test to troubleshoot this. Fuel pumps on these rarely fail but the filters are good for 50,000 miles or so if you get good gas.
post #5 of 14 Old 10-28-2018, 12:22 AM
blaustrom's Avatar
To decide what's up you need to do the fuel pump flow test.
https://www.stromtrooper.com/dl650-d...t-results.html
Then depending what you find decide what to do next.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 14 Old 10-28-2018, 12:36 AM
dmfdmf's Avatar
Pull the pump and clean the inlet sock. The high-pressure filter is probably fine unless you travel in areas with sketchy gas or have a rusty tank. My new-to-me Wee (April) that I bought with only 3700 miles on the ODO started whining at 7K miles and it turned out my inlet sock was plugged with fine black silt or grit.
It happened to my previous K7 Wee too so I have switched to a different gas station.
Next Up: ?
dmfdmf is offline
post #7 of 14 Old 10-28-2018, 01:52 AM
STCorndog's Avatar
^^^^^^^^^^maybe...maybe not. But trying what dmfdmf says is not a bad idea.
The sock on mine was cleaned first. Whined still.
Then I back flushed the HP filter. Fixed for a few thousand miles. Whined again.
Replaced the HP filter. Fixed.
I buy top tier gas all the time, premium usually.
I should add though, as well as whining, the bike would get where it would not run above 7,500 rpm or so, like it had a fuel cut off. Even with a clean filter system, the fuel pump was a little noisy, but I have great hearing.
post #8 of 14 Old 10-28-2018, 04:18 PM Thread Starter
I didn't do a flow test and decided to just pull it to check things out today. Low filter has residue but not completely covered. After shaking all the gas I could get out of the sealed unit, it seemed to be very discolored gas coming out onto a white towel.There is a small roundish chrome cylinder attached to the HP filter that the pump slides in to. Should this be pulled off the assembly?
post #9 of 14 Old 10-29-2018, 08:30 AM Thread Starter
Just out of curiosity would you think totally submerging the entire black HP housing in Techron fuel system cleaner for a few days and then flushing in gasoline until it emptied out clear and clean would be an alternative to spending $250 for a new one? I have no idea what the sealed unit looks like inside as to whether it would dissolve and clean it. Is it just 1 filter screen like the lower one but finer or is it a series of filters? If I buy a new one I will definitely tear the old apart to see how it's constructed!
post #10 of 14 Old 10-29-2018, 09:44 AM
Gert's Avatar
I take it that you have used the search fascilty of this site, using the search string for example as "fuel pump noise". One of the hits I found when using the sting, gives an option of something to try https://www.stromtrooper.com/4039394-post3.html. If you do try the advice, let us know how it worked out.
Gert is offline
Fuel Pump Location and Error Testing TechPoet DL650A - 2012-2016 2 12-28-2016 10:17 PM
Whistling fuel pump :) Weehemoth DL650 and DL650A - 2004 to 2011 10 03-23-2015 11:56 AM
Bike won't fire...fuel pump? chanster DL650 and DL650A - 2004 to 2011 19 08-30-2014 09:12 PM
Just got my WeeStrom Looking for Accessory Recomends WhiteyWeeStrom DL650 and DL650A - 2004 to 2011 26 10-29-2010 03:55 PM
