Chain thrown off, oil everywhere! - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #41 of 60 Old 10-18-2018, 05:21 PM
chicago's Avatar
Originally Posted by Sagebrush View Post
Lightening struck my tower crane a few times, I could feel it sitting in the cab. Not fun. But, better to ride it out than to climb down sometimes.
Sent from my SM-G960U using Tapatalk
those things would have a grounding system then? I would guess that's important.
14 tooth for me
chicago is offline
post #42 of 60 Old 10-18-2018, 06:13 PM
Sagebrush's Avatar
Yes, the static base most use is fairly deep in the ground for the structure, built in ground rod.
They usually have a big transformer at the base that's grounded normally.
Over the years lighting has damaged many of them. Especially the newer digital ones with too many computers and sensors.
I've fried some wiring too about 10 years ago, I really hated the old Honda 28 amp systems or whatever they were. They had those weak systems on a few models for years. I melted down a nice low miles ST1100 over 500 miles from home. Thankfully the ST1300 has an alternator!
chicago likes this.
Sagebrush is offline
post #43 of 60 Old 10-18-2018, 07:32 PM
have you even thought about just fixing it
if its just the mount that snapped and cases are not destroyed
i see no reason why it could be fixed?
brutalguyracing is offline
post #44 of 60 Old 10-18-2018, 08:04 PM
Sagebrush's Avatar
We need pics! I'm guessing the hole is too large to patch? On trips I carried the cold weld epoxy stick stuff and JB Weld. Never had to use it though.
I've taken three 525 chains to the breaking point on two different bikes, but I've managed to catch it before total failure.
One bike shop wouldn't put the new chain on when I got caught out on a trip, had to self install in their parking lot, used a clip master. At least they cut the chain for me, took them two tries though and they let me borrow a pair of vice grips and a nut.
Very odd that a bike dealer would refuse the work, a tech came out and helped tighten things back up. He didn't understand the manager either, they weren't that busy. Wish I could remember the dealer name. Total jerks running the place, they sold Yamahas near Abingdon, VA. Charged me way over retail for a cheap no name chain, I didn't complain though. I was glad to have it, lasted me only 8,000 miles though. But at least I could finish my trip to NY!
post #45 of 60 Old 10-19-2018, 12:16 AM
Judt installed a Tutoro oiler. Does a much better job than I ever did.
Hatchi is offline
post #46 of 60 Old 10-19-2018, 12:59 AM
Sagebrush's Avatar
I've had the tutoro for the last two chains, its a bit messy but it works for me very well especially on longer trips.
I run a 75w oil in the summer at about 3/4 turn out. Chains are lasting much longer, I just wipe the chain occasionally with an oily rag to get the light road grime or dirt build up off.
Nice install.
Hatchi likes this.
post #47 of 60 Old 10-19-2018, 06:13 AM
PerazziMx14's Avatar
Chain oilers a Dog send. With my Scott oiler once properly set up it was no more messy than other lubes, did a better job and kept the chain cleaner than new.
Pinelanerider, if your interested I have a Scott oiler I pulled one of my DR650 before I sold it. $80 and its yours.
If PLR isn't interested in the oiler if another local wants it same deal. Sorry to all the others I am not interested in shipping only F to F transaction on this.
PerazziMx14 is online now
post #48 of 60 Old 10-19-2018, 09:13 AM
Motor7's Avatar
Nice install.
So how many miles are you getting out of them when the chains are on the Tutoro?
'15 DL650XT
Motor7 is offline
post #49 of 60 Old 10-19-2018, 09:35 AM Thread Starter
PineLaneRider's Avatar
It may be repairable. I'm just not interested in taking the time or effort to do a JB Weld fix that may or may not hold up. Don't need another failure point when I'm out jarring around on a trail. I found an identical bike with lower miles that i am purchasing. I will then have a parts bike. Same color too, for when I need that tupperware piece that I will undoubtedly break sometime or other. All my farkles will swap over, I'll have a spare set of wheels that I can mount touring tires on for long road trips, and I can part out some pieces if I want. This is also nice and clean...for now...
PineLaneRider is offline
post #50 of 60 Old 10-19-2018, 02:01 PM
good to hear
wish you the best
but fyi one could have it welded (not jb welded) for piece of mine
just something to think about
best of luck
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 03:11 PM
A (Personal) Caution on Using Dupont Teflon Chain Lube, (Some Pics) Black Lab General V-Strom Discussion 73 11-26-2009 02:03 PM
