Chain thrown off, oil everywhere! - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #31 of 60 Old 10-18-2018, 07:42 AM
Actually there are several cases of Super Tenere final drive problems. They had some bearing and gear issues. Ours still spits out too many metal fragments when you drop the oil. But it is a Yamaha so no one believes they can have problems! They do not seem to just fail all at once leaving the rider stranded.
realshelby is offline
post #32 of 60 Old 10-18-2018, 09:42 AM
PerazziMx14's Avatar
The only manufacturers that do not have drive shaft issues are the ones who only produce chain drive, drive systems.
Guzzi, BMW, Honda, Kawasaki, Yamaha and any other manufacturer that uses shaft drives has experienced issues.
But there no fun in facts and perpetuating rumors, fear mongering and finger pointing based solely on what you've heard 2nd or 12th hand is gospel.
PerazziMx14 is online now
post #33 of 60 Old 10-18-2018, 04:04 PM
larolco's Avatar
If anyone in my neck of the woods wants a nice shiny chain, there's one laying in the middle of the Trans-Canada highway, eastbound, at 176th in Surrey. It's been there for a couple of days. Glad I wasn't behind him when it came off.
Sagebrush likes this.
DRZ400SK17
larolco is offline
post #34 of 60 Old 10-18-2018, 04:04 PM
STCorndog's Avatar
Find me a post (hell it is the interweb, find me 2) where a Tenere has coughed up a shaft and disabled a bike. The seal, well sure, some people ride them in creeks and mud. The seal is cheap, plus it is quick and easy to replace. Seal goes and you do not catch it, bearing will suffer.
Is yours showing fine metal or kibbles and bits. Mine had dirty oil the first few changes, which I attributed to moly assembly lube. After the third or fourth change, the oil is pretty clean now.
I am worried more about lightning much more than I am the shaft shitting the bed.
STCorndog is offline
post #35 of 60 Old 10-18-2018, 04:08 PM
STCorndog's Avatar
Originally Posted by V-Strom Ry 2 View Post
Lightning regularly hits the same place twice or more often. It's not like lightning strikes are completely random or something.
Unless we are talking pieces of metal like antennas and such, sticking way up high......uh, yeah lightning is by its nature random and rare when it hits the same spot twice. If you have been struck, twice you should work on improving your karma
And maybe stick to chain drives to.
post #36 of 60 Old 10-18-2018, 04:45 PM
STCorndog's Avatar
Now before you guys get your pitch forks and light your torches to march on Corndog's castle, I have owned a bunch of brands in my life. I know they all will (or can) break down leaving you sad. I have just never had it happen with my SuperVee in 100,000 miles or either of my Super Teneres in a combined 70,000 miles.
So experience has made me sort of endeared to Suzuki and Yamaha and it also has made me prejudice of some other brands.
BTW, those are real (and pissed off) alligators in my moat and they only get fed at election time when the candidates come to ask for my vote.
post #37 of 60 Old 10-18-2018, 04:45 PM
Sagebrush's Avatar
I changed my FJR drive oil every other oil change, same with the Hondas. I've seen 100k on them with zero issues. Chains and sprockets cost me more than any shaft drive bike.
Anything can fail though, but keeping a close eye on the used gear lube is always a good idea. I've had a number of riding buddies get burned by their BMW. Most of them switched to the Yamahas.
But I've been stranded by a Honda and my current Suzuki, both had a bad stator failure far from home. They can break at the worst time.
Sent from my SM-G960U using Tapatalk
STCorndog likes this.
Sagebrush is offline
post #38 of 60 Old 10-18-2018, 04:58 PM
Yes, that's the sort of thing I was referring to. So it does hit the same place more than once
V-Strom Ry 2 is offline
post #39 of 60 Old 10-18-2018, 05:02 PM
Sagebrush's Avatar
Lightening struck my tower crane a few times, I could feel it sitting in the cab. Not fun. But, better to ride it out than to climb down sometimes.
post #40 of 60 Old 10-18-2018, 05:03 PM
STCorndog's Avatar
The stator always worried me to. Around 75,000 miles I JB welded the spaces between the magnets on my Vee....they seemed visually fine though. Then I installed a voltmeter, which always read good charging.
I did have the high pressure filter clog up on me and I spent a nervous 8 hours limping the Vee home without being able to engage warp drive. It made it back to my house though, so I considered it a win.
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 03:11 PM
A (Personal) Caution on Using Dupont Teflon Chain Lube, (Some Pics) Black Lab General V-Strom Discussion 73 11-26-2009 02:03 PM
