Stator magnets & JB Weld - pictures? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 46Likes
post #1 of 76 Old 02-02-2018, 06:43 PM Thread Starter
NorcalDL1000's Avatar
I plan to take a look at my magnets and use JB weld (slow cure/marine) to keep the magnets in place as has been discussed on this forum. I've looked through this forum and Youtube looking for pictures or video of how the JB weld should be placed on the magnets, with no luck.
Does anyone have a linky to pictures or video of how to add the JB weld to the magnet area?
thank you!
NorcalDL1000 is offline
post #2 of 76 Old 02-02-2018, 09:30 PM
I've read about this but don't know it the stator is in an oil bath or not. If it is, you'd need to de grease the area and then even up the magnets and use a bit of the JB Weld to prohibit them from moving in the future. Apparently not a lot of JB is needed to do the job.
notacop is online now
post #3 of 76 Old 02-02-2018, 10:16 PM
It is an oily area.
post #4 of 76 Old 02-02-2018, 10:21 PM
pichulec's Avatar
I did it on my magneto rotor. Removed magnets from rotor, de-greased rotor and magnets (I didn't clean old epoxy from magnets) and reglued. Pic attached
I did it 4 months ago and no problems so far.
NorcalDL1000 likes this.
Bike is a lifestyle
pichulec is offline
post #5 of 76 Old 02-03-2018, 08:37 AM
That looks like a nice job of gluing the magnets into place. I don't see any JB Weld between them? That is something that I think makes this foolproof. Doesn't have to have the gap filled completely, just enough to form a bridge where there is a mechanical block keeping them from ever moving again.
The standard red and black packaged JB Weld is what you want to use. Do not use the quick setting version. The standard version is rated for continuous oil immersion and constant temps up to 400 degrees. Which will more than cover what it sees in this environment.
realshelby is offline
post #6 of 76 Old 02-03-2018, 09:07 AM
Karlos's Avatar
When I did mine I didn’t “glue” them, was afraid of contact between rotor and stator.
Pics here:
https://www.stromtrooper.com/dl1000-2...ml#post4833602
2004 DL1000
2004 KTM 525EXC plated
Karlos is offline
post #7 of 76 Old 02-03-2018, 02:04 PM Thread Starter
^^^ Thank you all for your replies - they were helpful.
post #8 of 76 Old 02-04-2018, 09:09 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
How did you remove the magnets without damage?
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #9 of 76 Old 02-04-2018, 09:44 AM
I know of a couple owners that have broken magnets trying to get them out!
There is no real need to remove magnets. You can simply ( and delicately ) insert a screwdriver between them until the correct separation is met. This means you are not going to "glue" under them. But, so far from what I have followed here and on the SV 1000 sites there is no benefit from putting JB Weld under the magnets. Seems to work just fine filling the gaps between them enough to form a mechanical separation barrier. Centrifugal force and magnetic attraction keep them against the rotor surface.
Mulewright likes this.
post #10 of 76 Old 02-05-2018, 04:03 PM
pichulec's Avatar
Mike
I slide them out of rotor.
There is small amount between them as well, but not much.
Bike is a lifestyle
pichulec is offline
