Stator magnets & JB Weld - pictures? - Page 8 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 46Likes
post #71 of 93 Old 02-18-2019, 09:12 AM
Originally Posted by aTuWitty View Post
So I'm gonna attempt to set the JB Weld tonight and I had a question- if I put masking tape across the top of the gap to stop the jb weld creeping out, will it tear away cleanly when the weld has set? I don't want to have to pick it all out. Any ideas?
There has been several guys put tape in there to seal the rear area and across the top in the back. Don't tape all the way across the gap, fill the back half with epoxy then put some more tape in across the magnets to cover the rest of the gap. Then fill that. Ideally you can allow the tape to sag ever so slightly. Either way, most owners are using a bit of sandpaper to clean off the bits of tape that stick and insure the epoxy is below the height of the magnet. Not hard to do at all with a Dremel tool!
DesertBike likes this.
realshelby is offline
post #72 of 93 Old 02-18-2019, 10:08 AM
Onboard Mass Damper
DesertBike's Avatar
FWIW, that's what it looked like when I did mine.
This is how it looked around a year later, when I had to replace a second factory stator.
I didn't fill the gaps - kinda wishing I had now! But it's held for just over 2 years, so I guess even a smaller amount of JB Weld will work.
DesertBike is offline
post #73 of 93 Old 02-18-2019, 09:15 PM
hoggdoc's Avatar
Location: The Great Northwest (Southwest Washington State)
Send a message via Skype™ to hoggdoc
Originally Posted by WildDoktor View Post
This may be a bit paranoid, but...the first JB Weld I put between my magnets "went away". I've re-done it and let the stuff sit for at least a week now. Last night I took a screwdriver to it to see if it would budge. Can anybody tell me if it looks like I did it right this time? (Or wrong?)
https://youtu.be/cu3IKaEvXKg
It doesn't look hard enough to me. JB Weld when mixed and cured should be very hard and machineable.
2003 Zuki V-Strom 1000
hoggdoc is offline
post #74 of 93 Old 03-18-2019, 03:57 PM
aTuWitty's Avatar
Well, I finally got around to doing this job for the THIRD time. I used 1/4" tile spacers (EXCELLENT idea, thank you!), masking tape between the magnets to stop the weld from creeping up the sides and I took care to make sure the tape was pushed in between the magnets so it didn't cause clearance issues. I have a few spots to sand down where I couldn't stop the creep.
Let me know what y'all think. The weld did trend toward the inside of the flywheel thanks to the magnets and as such it created a little hollow tube between each magnet.
I don't know how this will work, but I know that doing a small amount of weld has failed twice now and I'm so tired of it.
File Type: jpeg received_416802392461888_1552939156712.jpeg (174.5 KB, 19 views)
File Type: jpeg received_351758572098117_1552939169688.jpeg (204.7 KB, 16 views)
"Definitely do not sit on a DL1000. Big mistake. You'll end up buying one. Happened to me. True story."
-busarider54
"Purchasing a V-Strom from a Harley dealer does have poetic justice. Almost like removing a talented child from a meth house."
-ShortOnSkill
"I'm for moves that will help people get over the idea that it is ever okay to drink and drive."
-greywolf
aTuWitty is offline
post #75 of 93 Old 03-18-2019, 04:08 PM
The only two failures I know of using the JB Weld have one similarity. Both did not fill the rear part of the channel with epoxy. I think the oil is filling that area and then centrifugal force is acting to put a lot of pressure on the JB Weld that is in the front of the channel. I would fill the gap in the pictures all the way. I still don't think you have to fill the gap to the top, but equal height from from to back to keep the oil from puddling behind it.
Big B and DesertBike like this.
post #76 of 93 Old 03-24-2019, 06:31 PM
jeeves's Avatar
I had my magnets glued back on by a shop in Croatia in 2013.
Thy guy has done a lot of DL1000.
He uses 3M Scotch Weld 2214 and heats the whole thing for 100 minutes on 130C. He also balances the flywheel after that.
Unfortunately I don't have any pictures of the process or the machine he balances them on.
Don't ask...
jeeves is offline
post #77 of 93 Old 05-02-2019, 01:29 PM
Anybody have an extra flywheel magnet for DL1000 2002-2012?
bstromer1000! is offline
post #78 of 93 Old 05-07-2019, 08:35 PM
Am i missing something?
I spaced and bonded the magnets to the flywheel with the recommended JB weld. That all went fine. I taped off the magnets and rotor body so i could fill in in between the magnets without making a mess. When i tried to fill it in, the JB Weld would attract to the upper or outside of the magnet and would not allot to fill the hole.
Do i need to use a different product for filling in?
Thanks.
Kaine Beedenbender is offline
post #79 of 93 Old 05-08-2019, 07:33 AM
You just have to keep working at it to get the JB Weld into the crack.
post #80 of 93 Old 05-09-2019, 03:18 AM
Gert's Avatar
@Kaine, Have you tried making use of spacers? Remove the spacers once JB Weld has set, then fill in where the spacers were if necessary. Also use the correct JB Weld product as per the pix in post #49.
Gert is offline
